MS Access tables to Excel
3121
8
03-11-2020 03:27 PM
GIS_geek
New Contributor III
Hello.  I am trying to export two tables from an Access database to excel.  I have been able to connect to the database using the code provided.  But I have not been able to export the table to excel.  I also want to rename the field names that will display in excel (P_UpNumber = Upstream Manhole, P_DownNumber = Downstream Manhole).
import pyodbc
# MS Access DB connection
pyodbc.lowercase = False
conn = pyodbc.connect(r'Driver={Microsoft Access Driver (*.mdb, *.accdb)};' +
    r'DBQ=C:\Desktop\PACP.MDB;')
# Open cursor and execute SQL
cursor = conn.cursor()
cursor.execute('select P_UpNumber, P_DownNumber FROM T_PIPES');
for row in cursor.fetchall():
    print (row)
Prior to my machine being upgraded to Windows 10, I had  code that exported the rows to a csv without field names.  But now it does not export it and I do not receive any error messages.  My guess is that it has to do with the Access now being 64 Bit.  Any help will be much appreciated.  Thank you.
RandyBurton
One option would be to use the xlwt module, something like:
import pyodbc
import xlwt
    r'DBQ=DBQ=C:\Desktop\PACP.MDB;')
wb = xlwt.Workbook()
ws = wb.add_sheet("T_PIPES") # use table name for worksheet name
cols = ['Upstream Manhole', 'Downstream Manhole'] # renamed colum headings
wbRow = 0 # counter for workbook row
ws.write(wbRow, 0, cols[0]) # write column heading to first row
ws.write(wbRow, 1, cols[1])
    wbRow += 1 # increment workbook row counter
    ws.write(wbRow, 0, row[0])
    ws.write(wbRow, 1, row[1])
wb.save(r"C:\Path\to\PACP.xls")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Was your script connecting to the database and printing results?
GIS_geek
New Contributor III
Thanks Randy.
The code you provided did create the xls with column names.  Though it did not bring the data from the Access table.  To answer your question, my script does connect the the database and prints the results.  See attachment.  Not sure why the data is not exporting to the xls.
RandyBurton
Puzzling.  What if you try writing to a file instead of printing?  This would create a tab delimited file with an xls extension Excel may give a "file format" error, but it should open it.
import pyodbc
# open a file for writing
fw = open(r"C:\Desktop\PACP.xls","w") # edit path as needed
fw.write("{}\t{}\n".format('Upstream Manhole', 'Downstream Manhole')) # write a header row
for row in cursor.fetchall(): # loop through Access
    fw.write("{}\t{}\n".format(row[0],row[1]))
fw.close() # close file‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
You may wish to verify Access as being 64 or 32 bit.  You should also be using a matching 64/32 bit version of Python.
GIS_geek
New Contributor III
Randy, your updated code worked. But it concatenates the fields.
And I confirmed, the Access I have is 64 bit and I am using the conda package that comes with ArcGIS Pro.
by Anonymous User
Not applicable
This version is like Randy's above but uses csv so you wont get that file open error.  Change the pathtocsv variable to the path of your csv.
Edited for python 3 syntax
import pyodbc
import csv
csvpath = r'path to your csv'
# create a csv file (python 2)
# writer = csv.writer(open(csvpath, "wb"), delimiter=",")
# create a csv file (python 3)
writer = csv.writer(open(csvpath, "w"), delimiter=",")
writer.writerow(['Upstream Manhole', 'Downstream Manhole'])
# output cursor results to csv
   writer.writerow([row[0], row[1]])
del writer‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
GIS_geek
New Contributor III
Thanks for contributing Jeff.
I get the attached error on the following line
writer.writerow(['Upstream Manhole', 'Downstream Manhole'])‍‍
by Anonymous User
Not applicable
Yeah, the 'wb' is from python 2 and is indicating that it is in binary mode and is causing that error. In python 3 its just 'w' so just remove the 'b' in the writer and it should work ok.
GIS_geek
New Contributor III
Hello all.  I hope you are staying safe in this crazy 2020.  I came back to this issue I was having and discovered that my results were being exported to a csv.  What I found out is that it is being exported the path where I have the .py file saved (B:\Scripts\Python\CCTV).  I would like to save it to a different path (B:\Planning\GIS\CCTV) but after searching I have not been able to find the right code.  Below is the updated code
# Exporting relevant fields from CCTV Access (Master PACP 1.mdb) table to csv.
import pyodbc
import csv
import pandas as pd
print("Connecting to database.")
    r'DBQ=B:\Planning\GIS\CCTV\MASTER PACP 1.MDB;')
print("Executing SQL.")
cursor.execute('select P_PipeID, P_ChangeDate, P_CreateDate, P_UpNumber, P_DownNumber, P_LocationDetails,\
P_Material, P_PlaceName, P_RoadName, P_ScheduleLength, P_Size, P_YearLaid FROM T_PIPES');
# Open csv and iterate through results.
print("Converting to csv.")
with open('PIPES.csv', 'w', newline='') as f:
    writer = csv.writer(f)
        writer.writerow(row)
        #writer.writerow([row[0], row[2]])
cursor.close()
conn.close()
# Adding headers to csv
print("Adding header to PIPES.csv.")
with open('PIPES.csv', newline='') as f:
    r = csv.reader(f)
    data = [line for line in r]
    w = csv.writer(f)
    w.writerow(['PipeID', 'ChangeDate', 'CreateDate', 'UpManhole', 'DownManhole', 'LocationDetail',\
    'Material', 'PlaceName', 'RoadName', 'Length', 'Size', 'YearInstall'])
    w.writerows(data)
df = pd.read_csv('PIPES.csv')
df['SLID'] = df['UpManhole'] + df['DownManhole']
print("Done")
