Modify CSV writer script to define list of columns by field name
3268
21
11-26-2021 02:27 AM
David_Brooks
MVP Regular Contributor
I have a script that writes a CSV based on fields from a feature class. Currently, the columns are defined by a field list, and a Search cursor loops through each item in the list to write to the CSV.
The list is defined by the positions of each field in the list. However, if the field order ever changes on the Feature Class, this list goes to pot.
How do I rewrite it so that I can define fld_list_final as a list of strings that match the actual field names, instead of their positions in the list?
So, for example, instead of the list being fn[5], fn[6] etc, i want to be able to define it as 'TreeRef', 'Species', etc
   # Create CSV of data for schedule if there are veteran trees
   import csv
   import os
   def tableToCSV(input_tbl, csv_filepath):
       fld_list = arcpy.ListFields(input_tbl)
       fn = [fld.name for fld in fld_list]
       fld_list_final = [fn[3], fn[4], fn[5], fn[6], fn[7], fn[8], fn[38], fn[41], fn[22], fn[23], fn[24], fn[25], fn[26], fn[27], fn[28], fn[29], fn[30], fn[36], fn[40], fn[39], fn[33], fn[37]]
       with open(csv_filepath, 'w', newline='') as csv_file:
           writer = csv.writer(csv_file)
           writer.writerow(fld_list_final)
           with arcpy.da.SearchCursor(input_tbl, fld_list_final) as cursor:
               for row in cursor:
                   writer.writerow(row)
       csv_file.close()
   out_csv = csv_path+"\\"+(os.path.basename(fc_pnt))+".csv"
   tableToCSV(fc_pnt, out_csv)
   arcpy.AddMessage("CSV Generated.")
David
..Maps with no limits..
Tags (3)
DanPatterson
MVP Esteemed Contributor
import arcpy
import numpy as np
tbl = r"C:\Arc_projects\Test_29\Test_29.gdb\sq2"
flds = arcpy.ListFields(tbl)
fnames = [f.name for f in flds]
fnames
['OBJECTID', 'Shape', 'ids', 'CENTROID_X', 'CENTROID_Y', 'INSIDE_X', 'INSIDE_Y', 'PART_COUNT', 'PNT_COUNT', 'Sort_', 'Shape_Length', 'Shape_Area', 'Sort2_']
keepers = ['Sort2_', 'PNT_COUNT', 'PART_COUNT']
arr = arcpy.da.TableToNumPyArray(tbl, keepers)
# -- def time ----------------------------------------
def save_txt(a, name="arr.txt", sep=", ", dt_hdr=True):
    """Save a NumPy structured/recarray to text.
    Parameters
    a : array
        Input array.
        Output filename and path otherwise save to script folder.
    sep : separator
        Column separator, include a space if needed.
    dt_hdr : boolean
        If True, add dtype names to the header of the file.
    a_names = ", ".join(a.dtype.names)
    hdr = ["", a_names][dt_hdr]  # use "" or names from input array
    s = np.array(a.tolist(), dtype=np.unicode_)
    widths = [max([len(i) for i in s[:, j]])
              for j in range(s.shape[1])]
    frmt = sep.join(["%{}s".format(i) for i in widths])
    np.savetxt(name, a, fmt=frmt, header=hdr, comments="")
    print("\nFile saved...")
# now save it
save_txt(arr, name="c:/temp/test.csv", sep=", ", dt_hdr=True)
results
Sort2_, PNT_COUNT, PART_COUNT
0, 11.0, 1.0
1,  8.0, 1.0
2,  6.0, 1.0
3,  5.0, 1.0
4, 10.0, 1.0
5, 10.0, 1.0
6,  5.0, 1.0
... sort of retired...
DanPatterson
perhaps the suggestion of using a dictionary to alter field order when exporting to csv can be exploited
Solved: Changing Column Order with Python Export CSV - Esri Community
jcarlson
If you have a set list of field names that you want in your output, you can define those separately, then filter your field list with it. Try this? I don't have a dataset handy to test it on.
import csv
import os
    keepers = ['some', 'list', 'of', 'field', 'names']
    fn = [fld.name for fld in fld_list if fld.name in keepers]
        writer.writerow(fn)
        with arcpy.da.SearchCursor(input_tbl, fn) as cursor:
            for row in cursor:
    csv_file.close()
out_csv = f"{csv_path}\\{os.path.basename(fc_pnt)}.csv"
- Josh Carlson
Kendall County GIS
David_Brooks
@jcarlson thanks for the re-write, but I get
TypeError: list indices must be integers or slices, not str
....which i think is because Im not extracting items from a list by index, rather by string values. Any ideas?
David
jcarlson
What line is that error pointing you to? The change I made shouldn't really matter with respect to list indices.
- Josh Carlson
Kendall County GIS
David_Brooks
@jcarlson i've rewritten, and the csv now exports. however, the order of fields doesn't match the order i've written them in the keepers list
David
jcarlson
Looks like I missed quite a bit over the weekend! It looks like you've got your solution, but I would also like to throw in an ArcGIS Python API solution for you, in case you'd like to test it.
from arcgis.features import GeoAccessor
out_fields = ['your', 'output', 'fields', 'in', 'order']
df = GeoAccessor.from_featureclass('path/to/featureclass')
df[[out_fields]].to_csv('path/to/export.csv')
- Josh Carlson
Kendall County GIS
DanPatterson
import arcpy
import numpy as np
fnames
    Parameters
    a : array
        Input array.
    sep : separator
    dt_hdr : boolean
# now save it
results
0, 11.0, 1.0
1,  8.0, 1.0
2,  6.0, 1.0
3,  5.0, 1.0
4, 10.0, 1.0
5, 10.0, 1.0
6,  5.0, 1.0
David_Brooks
tried this code but get the error
  File "C:\Users\DAVID\Desktop\BS5837_TreePoint_v1.2.4.py", line 100, in <module>
  File "C:\Users\DAVID\Desktop\BS5837_TreePoint_v1.2.4.py", line 92, in save_txt
NameError: name 'np' is not defined
David
DanPatterson
Ahhh, forgot the old
import numpy as np
It is assumed in numpy world and oft forgotten since my IDE automatically loads my needed packages 😉
