Model / Script works in ArcMap but doesn't run when in Windows Scheduler
696
10-17-2019 03:47 AM
PanGIS
Occasional Contributor III
Hi everyone,
I' ve created a model that updates a table in PostgreSQL
The model runs perfectly as model and as tool as well.
Exported the Model into python script an it runs in Arc Python window.
I have created also a script that calls the toolbox and model inside and it works when run into Arc Python Window.
When I put it in Windows scheduler the task starts and completes but the table isn't updated meaning that the script doesn't run correctly.
I tried to run the same script in PyScripter and I get this error message:
Message File Name Line Position
Traceback
    <module> C:\Folder\script_startModel.py 15
    TableReadings2 C:\Folder\Toolbox.tbx 75
ExecuteError: Failed to execute. Parameters are not valid.
The value does not exist.
ERROR 000732: Output Location: Dataset Database Connections\database_publish.sde does not exist or is not supported
ERROR 000732: Input Table: Dataset database.sde.Building_Readings does not exist or is not supported
ERROR 000989: Tool CalculateField cannot use VB expressions for services
Failed to execute (ScriptReadings2).
I tried to run the same script in Windows CMD and I get this error message:
C:\Users\username>C:\python27\Arcgis10.5\python.exe C:\Folder\Script_startModel.py
  File "C:\Folder\Script_startModel.py", line 15, in <module>
    arcpy.ModelReadings2_Toolbox()
  File "C:\Folder\Toolbox.tbx", line 75, in ModelReadings2
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: Dataset database_publish.sde.Building_Readings does not exist or is not supported
The main issue seems to be the database which is not recognised.
Any idea?
Thanks
CCWeedcontrol
I've ran into this and for me I have to put the full path of the database\featuredataset\featureclass. It might be helpful if you posted your python code.
C:\Users\***\AppData\Roaming\ESRI\Desktop10.6\ArcCatalog\***_***_***.sde\yourfeaturedataset\featureclass
