mkl-service package failed to import error when using PyCharm Pro 2021.2.2
5267
09-18-2021 08:26 PM
GavinPaw
I have been attempting to set up PyCharm for use with Arcpy and ArcGIS Pro using the default environment and whenever I run a script it prints out the following
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\numpy\__init__.py:143: UserWarning: mkl-service package failed to import, therefore Intel(R) MKL initialization ensuring its correct out-of-the box operation under condition when Gnu OpenMP had already been loaded by Python process is not assured. Please install mkl-service package, see http://github.com/IntelPython/mkl-service
from . import _distributor_init
doesn't seem to matter what the script is. I've ran things ranging from just a print statement alone in a file, to some basic numpy array creation and manipulation and then a mkl.get_version_string() all of which seemed to work correctly outside of the message printing right beforehand
how would I go about fixing the error and if its not fixed what might actually break?
Subu_Swaminathan_GISP
@GavinPaw - I get the same error.
One important note is that the error occurs only with PyCharm Professional and not PyCharm Community edition.
GavinPaw
seems to be true, but I prefer to use the professional edition as I have it anyway...
I have continued to use it since this question was posted and it doesn't seem to break anything
it just prints an error every time any script is ran
PyCharm tech support suggested this  -  you can disable the helper script execution by disabling "Show plots in tool window" option in Tools | Python Scientific:
Once I turned that off, that warning went away for me in PyCharm Professional. As the warning was slowing down the start of execution of my scripts, it is a welcome workaround.
