MakeXYEventLayer from python addin dataset does not exist
3179
12-07-2015 08:52 AM
BenjaminSimpson
New Contributor III
I have a python addin which is running a custom toolbox. Part of the python script linked to the toolbox is suppose to use the arcpy.MakeXYEventLayer_management tool to create a point feature class from a table in my personal geodatabase. The problem I am having is that it keeps coming up with the error saying that the dataset does not exist or is not supported (below). When I do the same process manually it works fine and the MakeXYEventLayer tool creates the point feature class. I am not sure why it is unable to detect the database table.
ERROR 000732: XY Table: Dataset D:\SAGIS Conversion\SAGIS Models Test\Model_2_Wick River_T1 - Copy (17)\SAGIS_Wick_River_2.mdb\SimWaterBodiesT1 does not exist or is not supported
Failed to execute (MakeXYEventLayer).
Here is a snippet of my code:
import arcpy
import os
import sys
SAGIS_model_new = [arcpy.GetParameterAsText(0)]
model_pos = 0
for model in SAGIS_model_new:
     featureList = arcpy.ListFeatureClasses()
     if "SimWaterBodiesCent" in featureList:
          arcpy.AddMessage("SimWaterBodiesCent feature class already exists within " + Model_Name)
     else:
          SimWaterBodies = os.path.join(SAGIS_model_new[model_pos], "SimWaterBodies")
          SimWaterBodiesT1 = os.path.join(SAGIS_model_new[model_pos], "SimWaterBodiesT1")
          x_coords = "CentroidX"
          y_coords = "CentroidY"
          out_Layer = "SimWaterBodiesCent"
          spatial_reference = arcpy.Describe(SimWaterBodies).spatialReference
          arcpy.MakeXYEventLayer_management(SimWaterBodiesT1, x_coords, y_coords, out_Layer, spatial_reference, "")
          arcpy.FeatureClassToFeatureClass_conversion(out_Layer, simcat, "SimWaterBodiesCent")
          model_pos = model_pos +1
Can someone help me work out why this error message is persisting:
Thanks in advance for any help.
Ben.
FreddieGibson
Occasional Contributor III
Is your python addin calling the above script? Can you show have you're calculating the path to the geodatabase? Are you just pointing to a known location or did you include the data within the addin structure?
IanMurray
Could it be because of the parentheses that are in the file path to the table?
BenjaminSimpson
New Contributor III
Yes, my python addin is calling my custom toolbox which contains this script. Its being called from a toolbar button. The input for the tool is the SAGIS_model_new variable which allows the user to select the geodatabase. This is providing a list of selected geodatabase paths which the script is working from. This script will eventually run these processes and more on multiple geodatabases. The other arc tools which I have used in my full script have run correctly (e.g. AddGeometryAttributes, CreateTable and CreateFeatureclass).
Does that answer your question?
JamesCrandall
MVP Frequent Contributor
Probably because you are using Personal Geodatabase and things are executing in 64-bit processes (just a guess).
I'd recommend you move everything into a File Geodatabase and then run your script and see if it works.  Other than that, you'll likely need to explicitly set your script to run 32-bit because, well... that's MS Access (.mdb).
