Loop through folder of JPGS and copy their names to a geodatabase table
624
05-04-2020 01:42 PM
CarverCounty
import arcpy
import os
table = r'the location to the geodatabase table I wish to populate'
arcpy.env.workspace = r'the folder path to my jpgs'
for jpeg in arcpy.ListFiles("*.jpg"):
   output = os.path.splitext(jpeg)[0]
   print ouput
arcpy.CopyRows_management(output, table)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I am trying to loop through a folder that contains 500+ JPGs and copy their names to a geodatabase table.  I am able to successfully get to line 9 in my example code above and print all of my JPG names. However, when I get to line 10, I am unable to successfully copy these names to a new geodatabase table.  Would anyone have any suggestions?
Thanks in advance,
Craig
JoeBorgione
Take a look at  insert cursor.
JoeBorgione
CarverCounty
That did the trick.  Thanks Joe!
