List the sources of each of the "map layer"
1227
09-15-2014 05:01 PM
PierreWeisse
I try to get the source of each "map layer".
Does anyone have an idea?
I need a syntax like this:
map layer: ... , source: ...
map layer: ... , source ...
This is the beginning of code
import arcpy, os
path = "....."
for fileName in os.listdir (path):
        fullPath = os.path.join (path, fileName)
        if os.path.isfile (fullPath):
            basename, extension = os.path.splitext (fullPath)
            lyrname = arcpy.mapping.Layer (fullPath)
                lyrlist = arcpy.mapping.ListLayers(lyrname)
                print "Nom du Fichier:   "
                print fileName
                print""
                print "Nom de la couche :  "
                print lyrname
                print""
                print "Couches contenu:   "
                print lyrlist
                print""
RESULT:
Nom du Fichier:
DTSI_aires_protegees_provinciales.lyr
Nom de la couche :
Couches contenu:
[<map group layer u'aires_protegees_provinciales'>, <map layer u'Aires prot\xe9g\xe9es provinciales marines'>, <map layer u'Aires prot\xe9g\xe9es provinciales terrestres'>]
Thank you
DarrenWiens2
MVP Honored Contributor
Untested, but I would try:
print lyrlist[0].dataSource
Or, loop through your list of layers, changing the index number, instead of [0].
DanPatterson_Retired
This link Layer information in folders will give you a basis
