LayerToKML_conversion Tool
352
10-17-2017 05:53 AM
FlaynerRessoni
I'm using the LayerToKML_conversion tool in my python script published on ArcGIS Server as a GPServer. At the first time a call the service, the script generates the KML correctly, only the fist time. If I call the service again the KML is created with wrong values at coordinates, using "," (comma) as decimal separetor. If a restart the service (GPServer), at the fist time will create the KML correctly again. I've tried to set the locale in my python script but it doesn't work. How can I fix this problem?
JosephDavies
New Contributor III
Hi Flayner,
I also have this problem.
Did you manage to solve it?
Joe
