Jupyter Notebook: Runtime Error (Python-GIS)
1910
11
01-30-2020 12:58 PM
DWR_JessicaSwift
New Contributor II
I am taking a Python class where we are using Anaconda and Jupyter notebooks. I received the error below, anyone know what this means and how to fix it?  Thanks!
Error
Tags (3)
by Anonymous User
Not applicable
In order to use arcpy you have to have ArcGIS Pro installed and licensed. If you have it installed and licensed, try opening it (and leaving it open) and then running the script.
DWR_JessicaSwift
New Contributor II
My professor specifically told us as a class to not install ArcGIS Pro and only ArcGIS Desktop. I'm the only one in my class that is showing this error.
by Anonymous User
Not applicable
Have you opened and licensed ArcMap?
DWR_JessicaSwift
New Contributor II
Yes, I am using my 1-year student licences.
DanPatterson_Retired
It seems to go way back to the "import arcpy" line.
ArcMap is installed on your machine properly?
Can you do an "import arcpy" without issue?  If you can't then did you check out the professor's html file about how to install the "classtools" module?
DWR_JessicaSwift
New Contributor II
In past notebooks, I was able to "import arcpy" just fine. It wasn't until this time that the error occurred... it's very odd. My professor confirmed that I installed the "classtools" module correctly.
start an empty notebook and run one line at a time
DWR_JessicaSwift
New Contributor II
DWR_JessicaSwift
New Contributor II
Now I just skipped the notebook I was working on (the one giving me the errors) then tried the next Notebook in my assignment list and everything worked. Could the issue be with the notebook I was sent to work on?
