Iterative Zoom to and export to JPG
7079
13
11-14-2011 07:40 AM
AnthonyTimpson2
I have been trying to string together a simple script to read through a Grid.shp, Zoom to each feature, Export that image to a jpg with a world file with a filename based on the Grid index of the iterated row.
i tried to make this with Modelbuilder but it lacks the functionality it seems
I am absolutely green when it comes to python and I would greatly appreciate a nudge in the right direction.
thanks
JakeSkinner
Esri Esteemed Contributor
Just add the parcels to the map, save the MXD and then run the code.  The parcels should then be included.
nathanbush
Right, I didn't save the mxd before I ran the code.
Thanks.
AnthonyTimpson2
You Sir are a Steely Eyed Missile man. Thank you!!
Thiru_P
Thanks Jake, you are a gem. It worked perfectly.
I wanted to Export the JGW world file for JPEGs too so I modified it and it saved many days of manual work. Thumbs up
mapping.ExportToJPEG(mxd, r"C:\temp\Map_" + str(x) + ".jpg", df, df_export_width=2209, df_export_height=1663, world_file=True)
