#LEGENDSTUFF: print "legende generieren" legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","Legend")[0] legend.autoAdd = True while legend.isOverflowing == True: legend.elementHeight = legend.elementHeight +0.1
print "START map production" print "arcpy and os importieren" import arcpy import os, sys, string print "done arcpy and os and so on import" #Workspacedefinitionen workspace = r"H:\Desktop\Masterarbeit\test\RESULTATE" arcpy.env.workspace = workspace out_dir=r"H:\\Desktop\\maps\\e95ci\\" counter = 1 name_var= "test__" + str(counter) + ".jpg" outfile = os.path.join (out_dir, name_var) #Specifies layer file with the symbology you want to apply to the other raster layers sourceLayer1 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI.lyr") sourceLayer2 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_95CI_diff.lyr") sourceLayer3 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean.lyr") sourceLayer4 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\E_mean_diff.lyr") sourceLayer5 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_depos_diff.lyr") sourceLayer6 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_deposited.lyr") sourceLayer7 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_pass_diff.lyr") sourceLayer8 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_passages.lyr") sourceLayer9 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Nr_tree_impacts.lyr") sourceLayer10 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI.lyr") sourceLayer11 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_95CI_diff.lyr") sourceLayer12 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean.lyr") sourceLayer13 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Ph_mean_diff.lyr") sourceLayer14 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach Probability [%].lyr") sourceLayer15 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Reach_prob_diff.lyr") sourceLayer16 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol.lyr") sourceLayer17 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Rvol_diff.lyr") sourceLayer18 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Tree_impact_heights.lyr") sourceLayer19 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax.lyr") sourceLayer20 = arcpy.mapping.Layer(r"H:\Desktop\Masterarbeit\test\RESULTATE\lyr_files_neu\Vmax_diff.lyr") #Specifies Functions def shortname(name): name = name.rpartition("\\SH_")[2] print name name = name.replace(".","_") name = name.replace("\\","_") name = name.replace("_mdb_","_") print "this is the used name: "+ name return name print "specify mxd" #Specifies mxd mxd = arcpy.mapping.MapDocument(r"H:\\Desktop\\Masterarbeit\\test\\test1.mxd") print "done mxd spezifizieren" print "specify dataframe" #Specifies dataframe of interest df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] print "done specify df " #Turns all layers off print "turn visibility of all layers off" for lyr in arcpy.mapping.ListLayers(mxd,"",df): lyr.visible = False arcpy.RefreshTOC() arcpy.RefreshActiveView() print "visibility = False" #Turns backgroundlayers on print "turn backgroundlayer on: Visibility = true" for lyr in arcpy.mapping.ListLayers(mxd, "hill*", df): print lyr lyr.visible = True arcpy.RefreshTOC() arcpy.RefreshActiveView() for lyr in arcpy.mapping.ListLayers(mxd, "up*", df): print lyr lyr.visible = True arcpy.RefreshTOC() arcpy.RefreshActiveView() for lyr in arcpy.mapping.ListLayers(mxd, "swiss*", df): print lyr lyr.visible = True arcpy.RefreshTOC() arcpy.RefreshActiveView() print "background = visible" #lEGENDSTUFF: print "legende generieren" legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","Legend")[0] legend.autoAdd = True while legend.isOverflowing == True: legend.elementHeight = legend.elementHeight +0.1 print "start withE_95CI" #Loops through the layers given in the quotas (eg. beginning with E_95CI) and creates a list of Layers: for lyr in arcpy.mapping.ListLayers(mxd, "E_95CI", df): print lyr if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer1) #For Each: Turn it on: lyr.visible = True print " visible: on" name =lyr.dataSource name=shortname(name) #name = name.rpartition("\\SH_")[2] #print name #name = name.replace(".","_") #name = name.replace("\\","_") #name = name.replace("_mdb_","_") print "this is the used name: "+ name arcpy.RefreshTOC() print " TOC refreshed" arcpy.RefreshActiveView() print " Active View refreshed" print "exporting .JPG" mxd.activeView = "PAGE_LAYOUT" arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\maps\\e95ci\\SH_" + name+ ".jpg") lyr.visible = False #legend=arcpy.mapping.ListLayoutElements(mxd,"LEGEND_ELEMENT","")[0] #legend=arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT")[0] #legend.autoAdd = True #newlz added lazers will be automaticallz added to the legend #legend.elementHeight=4 #legend.elementWidth=4 for lyr in arcpy.mapping.ListLayers(mxd, "N*", df): print lyr if lyr.isRasterLayer: arcpy.ApplySymbologyFromLayer_management(lyr, sourceLayer6) #For Each: Turn it on: lyr.visible = True print " visible: on" print " this is the Source" name =lyr.dataSource name=shortname(name) print "this is the used name: "+ name arcpy.RefreshTOC() print " TOC refreshed" arcpy.RefreshActiveView() print " Active View refreshed" print "exporting .JPG" mxd.activeView = "PAGE_LAYOUT" arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\maps\\nr_deposited\\SH_" + name + ".jpg") lyr.visible = False # #print legend #legend=arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT")[0] #legend.autoAdd = True #newlz added lazers will be automaticallz added to the legend #legend.elementHeight=4 #legend.elementWidth=4 print "done_" #print "start reach_probability" ##Loops through the layers given in the quotas (eg. reach_probability) and creates a list of Layers: #for lyr in arcpy.mapping.ListLayers(mxd, "reach_probability", df): #For Each: Turn it on: # lyr.visible= True # arcpy.RefreshTOC() # arcpy.RefreshActiveView() # arcpy.mapping.ExportToJPEG(mxd, r"H:\\Desktop\\map_export\\" + outfile, df) #print"done_2" #Saves mxd print "__________________________________________" print "_xxx____xx___xx___x__xxxxx________________" print "_x__x__x__x__x_x__x__x____________________" print "_x__x__x__x__x__x_x__xxx__________________" print "_xxx____xx___x___xx__xxxxx________________" print "__________________________________________" #Deletes the reference to the mxd from memory (not the actual mxd file) del mxd
