Invalid floating point operation. arcpy (ArcSDE only)
5124
13
02-26-2015 05:50 AM
MarcGoetzke
I always get this Error when i do simple raster calculations with arcpy. i use PyScripter 2.7.5 and ArcGIS 10.2.1 :
Exception class: EInvalidOp
Exception message: Invalid floating point operation.
Exception address: 00007FF93BB646BE
PyScripter version : 2.5.3.0 x64
Python DLL : python27.dll
Python Engine : peInternal
I think its an ArcSDE only memory/cache problem. I tried things like arcpy.ClearWorkspaceCache_management() but it didnt help.
Any suggestions?
Thx
My Program:
#simple raster calculation of a list of rasters
outRas = Int(Raster('test1') + Raster('test2'))
outRas.save(destination + '/' + 'test3')
DanPatterson_Retired
Where is destination defined?  something is incomplete, does your first posted line work? have you tried
outRas.save()   without specifying a location?
VandanaRaghunathan
Hello Marc,
Can you try adding a .tif extension to your output raster?
outRas.save(destination + '\\' + 'test3.tif')
-or-
import os
outRas.save(os.path.join(destination, 'test3.tif')
Vandana
without the extension, it will produce an esri grid, which is preferable to tifs
VandanaRaghunathan
Hello Dan,
That is correct, without extension it will be an esri grid. However, esri grid has the following limitations and if they are not met, it will error out:
Storage limitation
The name of a grid is limited as follows:
It cannot be stored using spaces.
It cannot start with a number.
It cannot be longer than 13 characters (a multiband grid is allowed up to 9 characters).
There is a limit to the number of files that can be stored in an INFO directory for both coverages and grids. This total is approximately 10,000. Therefore, this limits the number of grids you can store in a workspace. For example, the following lists the theoretical maximum number of grid datasets that can be stored in a single workspace directory:
Fewer than 5,000 floating point grids, or
Fewer than 3,333 integer grids, with VATs (fewer than 5,000 if no VATs), or
Fewer than 10,000 grid stacks
In addition, there is a limit on the number of characters allowed for a GRID path in windows. The path cannot be longer than 120 characters (including the GRID name)
Esri Grid format—Help | ArcGIS for Desktop
35317 - Do GRID paths have a limit on the number of characters allowed on Windows platforms?
Vandana
and none of these are an issue if you know what you are doing... sorry ... you are barking at the wrong old dog
XanderBakker
Esri Esteemed Contributor
Apart from the output destination being unclear, the inputs are also "incomplete". Running your code from PyScripter, will require the import of arcpy and defining where the inputs can be found. If not specifying the entire path to the input data you should defined the arcpy.env.workspace where the data resides. May need to checkout the spatial analyst extension too.
So please post the entire code you are running. If possible attach (part of) the inputs or provide more information on the type of raster, size, projection, etc. These could all influence.
Did you try to run the code from the python window inside ArcMap? If so, is the same error occurring?
MarcGoetzke
Sorry this is the whole program:
import arcpy, os
from arcpy import env
from arcpy.sa import *
arcpy.CheckOutExtension("spatial")
def main():
            OD_path = 'S:/Project/Raster1'
            DD_path = 'S:/Project/Raster2'
            destination = 'S:/Project/Output'
            liste = ('n','nh4','no3')
            for chem in liste:
                liste2 = ('te','tu','ta')
                for item in liste2:
                    OD = OD_path + '/' + '%s_s%s09'%(chem, item)
                    DD = DD_path + '/' + '%s_t%s09'%(chem, item)
                    Out = '%s_f%s09'%(chem, item)
                    outRas = Raster(OD) + Raster(DD)
                    outRas.save(destination + '/' + Out)
if __name__ == '__main__':
    main()
MarcGoetzke
thx for the replies
XanderBakker
The problem might be data related, but could you try and replace the + with using arcpy.sa.Plus?
import arcpy, os
def main():
    OD_path = r'S:\Project\Raster1'
    DD_path = r'S:\Project\Raster2'
    destination = r'S:\Project\Output'
    arcpy.CheckOutExtension("SPATIAL")
    for chem in liste:
        for item in liste2:
            OD = os.path.join(OD_path, "{0}_s{1}09".format(chem, item))
            DD = os.path.join(DD_path, "{0}_t{1}09".format(chem, item))
            Out = "{0}_f{1}09".format(chem, item)
            # outRas = Raster(OD) + Raster(DD)
            outRas = Plus(OD, DD)
            outRas.save(os.path.join(destination, Out))
    # arcpy.ClearWorkspaceCache_management()
    arcpy.CheckInExtension("SPATIAL")
    main()
BTW: you can increase readability of the code by using syntax highlighting for your code (see: Posting Code blocks in the new GeoNet )
