how to update field with name of FC for list of FCs ?
6441
16
02-10-2015 02:49 PM
GabrielBacca-Cortes
Hi Everybody -
I am trying to fill in the attribute in a newly created field 'Particle', with the name of the FC, which will be changing for a list of FCs. I've tried using 'CalculateField', with which I get the error: 'NameError: name 'xy_1' is not defined', where 'xy_1' is the name of the FC going through the loop.
I've tried using 'UpdateCursor' and I get the error: "  'list' object has no attribute 'setValue'  ".
This is the code I've written so far:
fieldName1 = "Particle"
fieldType1 = "TEXT"
fieldlength = 20
wildcard = ""
fctype = ""
try:
    fcList =  arcpy.ListFeatureClasses(wildcard, fctype)
    # print fcList2
    for fc in fcList:
        print fc
        arcpy.AddField_management(fc,fieldName1,fieldType1,"","",fieldlength,"","NULLABLE")
[with:]
        desc = arcpy.Describe(fc)
        val = desc.name
        print val
        arcpy.CalculateField_management(fc, fieldName1, val, "PYTHON_9.3")
[OR:]
##        curs =  arcpy.da.UpdateCursor(fc,fieldName1)
##        for row in curs:
##            desc = arcpy.Describe(fc)
##            val = desc.name
##            print val
##            row.setValue(fieldName1,val)
##        curs.updateRow(row)
##        del curs, row
XanderBakker
Esri Esteemed Contributor
You're welcome...
BlakeTerhune
In the line where you open the update cursor, why do you have extra parenthesis around fld_name?
with arcpy.da.UpdateCursor(fc, (fld_name)) as curs:
TomSellsted
Blake,
It must be a tuple.  The extra parenthesis make it a tuple.
Regards,
Tom
BlakeTerhune
But the Esri documentation for the Update cursor says:
For a single field, you can use a string instead of a list of strings.
I'm not trying to be a nit-pick know-it-all, I'm just trying to understand.
TomSellsted
Blake,
You are correct, the docs do say you can use a string for a single field.  In this case just a coding preference.  If you had more fields, the tuple would already be in place.
Regards,
Tom
BlakeTerhune
Ah, yes, I follow now. However, I think you have to put an extra comma after the variable inside the parenthesis to make it a true tuple.
fld_name = "Particle"
print fld_name
print (fld_name)
print (fld_name,)
produces:
Particle
Particle
('Particle',)
GabrielBacca-Cortes
Blake - yes, it is meant for a list of fields, which in my case is only one.  As it is use in this link ArcGIS Help 10.1 , scroll down to the updateRow function.
Gabriel
