How to update a field with values from another field in table?
1625
02-11-2014 01:27 AM
808707
New Contributor III
Hello,
I have a big dataset with a field of values ranging from 1 to 10.
I want to update another field with a string depending on which value is in the other field.
So for example:
1 = Woodland
2 = Arable
3 = River, etc etc
I was wondering how I would go about this in arcgis?
I have done something similar with SQL using an IIF function but am struggling with how to figure it out.
Thanks for any help
JakeSkinner
Esri Esteemed Contributor
Hi Mark,
Here is an example on how to do this using the arcpy.da.UpdateCursor (10.1 or beyond is required):
import arcpy from arcpy import env env.workspace = r"C:\temp\python\test.gdb"  fc = "featureClass"  with arcpy.da.UpdateCursor(fc, ["field1", "field2"]) as cursor:     for row in cursor:         if row[0] == 1:             row[1] = 'Woodland'         if row[0] == 2:             row[1] = 'Arable'         ......             .....         cursor.updateRow(row)  del cursor, row
JakeSkinner
Hi Mark,
New Contributor III
Hi Mark,
import arcpy
fc = "featureClass"
    for row in cursor:
        if row[0] == 1:
            row[1] = 'Woodland'
        if row[0] == 2:
            row[1] = 'Arable'
del cursor, row
Thankyou very much that worked a treat 🙂
