So I created a GP service where a user can extract data from a WFS and convert it into KML or shapefile. So when the user selects the layer they have the opportunity to select features with the select option from the GP tool service. The service has a limit set to 1000, but if I select more than 1000 feature it will still process more than 1000. So my issue is if the user forgets to select the features it will process the entire layer which has over a million features. The tool will just run and will take forever to finish. With 100 people using this service, I expect to have someone forget to select items and try to export everything by accident. As you can see this would cause a bad user experience and could slow down the server.
How would I go about this ?
