How to force python script (=geoprocessing service) to return results???
2965
10-16-2014 08:40 AM
J_B__K_
New Contributor III
Hi!
I need to make a little geoprocessing service based on python script...
Meaning of the service is easy: receive JSON, look if there are any features of one feature class in geodatabase and return the count of features...
General idea of script (as it looks like as a desktop script - thats why there are "AddMessage") is this:
import arcpy data="Database Connections\myDB.sde\MYDB.DATAOWNER.data" data_fl=arcpy.MakeFeatureLayer_management(data) json=arcpy.GetParameter(0) sr=arcpy.Describe(vo).spatialReference polygon=arcpy.AsShape(json,True) polygon.projectAs(sr) polygon_fl=arcpy.MakeFeatureLayer_management(polygon) arcpy.SelectLayerByLocation_management(data_fl,"INTERSECT",polygon) if arcpy.GetCount_management(data_fl).getOutput(0)!="0":     arcpy.arcpy.AddMessage("you have chosen "+arcpy.GetCount_management(data_fl).getOutput(0)+" features") else:     arcpy.arcpy.AddMessage("no chosen features")
But - I know this is not way how to get some results from geoprocessing service (if i publish this script). How to force python script (=geoprocessing service) to return results??? It must be easy, I think this is kind of "newbie" question, Im still learning...
Thanks for any help!
JasonScheirer
Occasional Contributor III
Add a second parameter, datatype Long and type Output. At the end of your script do this:
count = int(arcpy.GetCount_management(data_fl)[0])
if count > 0:
    arcpy.arcpy.AddMessage("you have chosen {0} features".format(count))
else:
# Set as actual output
arcpy.SetParameter(1, count)
JasonScheirer
if count > 0:
else:
