How to create Grid Index of hundreds of Aerial TIF Images
810
01-18-2018 02:49 PM
BenVan_Kesteren1
Hey All,
I am trying to find the tool that would be useful in creating a grid index showing the extent (and ideally, the associated filename), of each of my several hundred TIF files containing our Aerial Photography.
I am sure I can automate something with Python if I knew what tool to use.
In the past we had been supplied this file from the creator of the Aerial Imagery, but this time they did not, and unfortunately I did not specify this in our contract.
This is what I am after:
This is all that I have got:@
Any direction for someone in need??
NathanDuncan
Cheers
BenVan_Kesteren1
Just a note to Future Me, there is a Geoprocessing tool called Add Geometry Attributes, works a treat!
DanPatterson_Retired
Fishnet  or Mosaic Dataset you might want to look at these prior to springing into full-fledge coding.  At least fishnet can provide a simple framework and mosaic dataset may remove the need altogether
BenVan_Kesteren1
