How to add two tables in Geodatabase view without any join between them?
2463
10-19-2015 07:08 AM
SaidAkif
New Contributor III
Hi all
I want to add two tables in geodatabase view (see attached). Those two table can not be related (attributes tables)
I am struggling with the SQL statement
Thanks
ChrisSmith7
Without a join? Something like this in SQL maybe?
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_NULLS ON
GO
if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[v_gis_view_test]') and OBJECTPROPERTY(id, N'IsView') = 1)
drop view [dbo].[v_gis_view_test]
GO
COMMENTS...
CREATE VIEW dbo.v_gis_view_test
AS
SELECT
  table1.f1,
  table1.f2,
  table1.f3
FROM
  dbo.theTableOne table1
UNION
SELECT
  table2.f1,
  table2.f2,
  table2.f3
FROM
  dbo.theTableTwo table2
GO
SET QUOTED_IDENTIFIER OFF
GO
SET ANSI_NULLS ON
GO
In ArcGIS, I believe you would just add the view name, "v_gis_view_test" in this case, in the name box, and the select clauses in the expression box. Is this what you're looking to do?
SaidAkif
New Contributor III
Thanks
I tried in arcCatalog with New/View with the following code:
SELECT
  gkmigeodatabase.NCR.AB_WetlandsGrid_25km.OBJECTID,
  gkmigeodatabase.NCR.AB_WetlandsGrid_25km.PageName,
  gkmigeodatabase.NCR.AB_WetlandsGrid_25km.percentage
FROM
UNION
SELECT
  gkmigeodatabase.NCR.BC_WetlandsGrid_25km.OBJECTID,
  gkmigeodatabase.NCR.BC_WetlandsGrid_25km.PageName,
  gkmigeodatabase.NCR.BC_WetlandsGrid_25km.percentage
FROM
The problem is that no geometry is loaded
After, I right click on my view to load data:
unfortunately, I got this error
I want notace that my feature classes have exactly the same schema
thanks for your help
