How do I delete a network analyst layer (i.e., Service Area, Closest Facility) using python 3 (ArcGIS Pro)?
2114
13
07-13-2019 06:23 PM
AndrewClark2
New Contributor III
I am building a toolbox using Python 3 in ArcGIS Pro 2.4. It involves a series of network analysis processes, including closest facility and service area. I am using arcpy.na.MakeClosestFacilityAnalysisLayer and arcpy.na.MakeServiceAreaAnalysisLayer. I am able to create them no problem, but I am having lots of trouble with manipulating them, including:
  • I cannot select the location where they are stored - they always get placed in the default GDB even though I am trying to put them "in_memory";
  • I cannot name them something meaningful - They always are named ServiceArea1, Service Area2; and
  • I cannot delete the final layer using python (arcpy.Delete_management) once I am done with it - so every time I rerun the syntax it adds a new file with the wrong name (e.g., ServiceArea2) and my tool crashes.
Anyone have any suggestion on how to fix this and make it work correctly? I want to be able to create it in a specified location, name it something that is meaningful and then delete the file when it is done.
Thanks!
Andrew
MelindaMorang
Hi Andrew.  Your script works fine with the addition of this line:
ServArea.defaultImpedanceCutoffs = [1]
Seems like you shouldn't need this because all your facilities have explicitly-set break values in the Breaks field, but for some reason it's getting confused.  I'll log a bug on our end to address this item of confusion, but I think if you add this to your code in the part where you're setting the service area properties, you should be good to go.
DanPatterson_Retired
If you are using ArcGIS Pro 2.4, there is a new arcpy network analysis module
What is the Network Analyst module (arcpy.na)—Network Analyst module | ArcGIS Desktop
The differences between the *.na and *.nax module are briefly discussed here
Choosing between the modules (arcpy.na and arcpy.nax)—Network Analyst module | ArcGIS Desktop
Migration differences, here
Migrating arcpy.na to ArcGIS Pro—Network Analyst module | ArcGIS Desktop
And of course the one you aren't going to like
Write geoprocessing output to memory—ArcGIS Pro | ArcGIS Desktop
But I can't remember if this was the same for pre-2.4
Memory-based workspaces do not support geodatabase elements such as feature datasets, subtypes, domains, representations, topologies, geometric networks, or network datasets.
So file geodatabases are a need.
AndrewClark2
New Contributor III
Hi Dan.
Thanks so much for sharing and I think I figured out most of the conversion to the arcpy.nax module. I was wondering if you can point me to anything that can provide a list of fields for the fieldmapping associated with service area facilities?
My original code added locations as follows and note that I assigned "Breaks_Meters" to the variable cutoff:
arcpy.na.AddLocations(layer_object, facilities_layer_name, facilities, "Name CentreID #;CurbApproach # 0;Attr_Minutes # 0;Attr_Meters # 1;Breaks_Minutes # #;Breaks_Meters cutoff 1", "5000 Meters", None, "RoadsNetwork SHAPE;NetworkDataSet_Junctions NONE", "MATCH_TO_CLOSEST", "APPEND", "NO_SNAP", "5 Meters", "EXCLUDE", "RoadsNetwork #;NetworkDataSet_Junctions #")
When I tried to use a similar code below I get an error message: File "<string>", line 12, in <module> KeyError: 'Breaks_Meters'
arcpy.nax.MakeNetworkDatasetLayer(nds, nd_service_area)
ServArea = arcpy.nax.ServiceArea(nd_service_area)
ServArea.distanceUnits = arcpy.nax.DistanceUnits.Meters
ServArea.travelMode = travel_mode
ServArea.outputType = arcpy.nax.ServiceAreaOutputType.Polygons
ServArea.geometryAtOverlap = arcpy.nax.ServiceAreaOverlapGeometry.Overlap
# MAP FIELDS FOR FACILITIES
fm_sa = ServArea.fieldMappings(arcpy.nax.ServiceAreaInputDataType.Facilities, True)
fm_sa["Name"].mappedFieldName = "CentreID"
fm_sa["Breaks_Meters"].mappedFieldName = "cutoff"
ServArea.load(arcpy.nax.ServiceAreaInputDataType.Facilities, Scratch + r"\fac_p", fm_sa)
result_sa = ServArea.solve()
result_sa.export(arcpy.nax.ServiceAreaOutputDataType.Polygons, gdb + "\FinalAnalysis\SrvArea_Final")
Network Analyst‌ shared to there to see if some of the experts can follow up
AndrewClark2
New Contributor III
Hey Network AnalystPython‌ experts. Does anyone have any suggestions for me to accomplish this? I am using NAX.
Thanks!
MelindaMorang
Hi Andrew.  Glad you're putting nax to good use.
Documentation for the Service Area input fields is here: https://pro.arcgis.com/en/pro-app/arcpy/network-analyst/servicearea-input-data-types.htm
AndrewClark2
New Contributor III
Just to confirm. If I want to assign dynamic buffer sizes, I need to assign
the field name to breaks? Or do I need to cursor through each row of
facilities and place the actual value in the breaks field?
Just want to make sure I understand the process correctly.
Andrew
MelindaMorang
When you use the load() method to load your input features into Facilities, use field mapping to assign your breaks field to the Breaks field in Facilities.
Alternatively, if you are loading facilities using an insert cursor, you just need to set the desired values directly into the Breaks field.
load() and insert cursor are just two ways of accomplishing the same thing - inserting facilities.
AndrewClark2
New Contributor III
This makes perfect sense to me Melinda Morang‌. I am still getting an error for some reason.
'''python
import arcpy
from arcpy import env
import os, datetime
import numpy as np
import math
arcpy.CheckOutExtension("network")
path = r"C:\afclark82\ChildCare_Final"
gdb = r"C:\afclark82\ChildCare_Final\ChildCare_Final.gdb"
nds = gdb + r"\Network\NetworkDataSet"
facilities = gdb + r"\Locations\ChildCareLocations"
incidents = gdb + r"\Locations\ChildHomeLocations"
nd_close_fac = "ShortRoute"
nd_service_area = "ServiceArea"
Scratch = r"C:\afclark82\ChildCare_Final\Scratch.gdb"
shortPath = Scratch + r"\ShortestPaths"
serviceAreas = Scratch + r"\ServiceAreas"
travel_mode = "Driving"
if arcpy.Exists(shortPath)==False:
   arcpy.CreateFeatureDataset_management(path+ r"\Scratch.gdb", "ShortestPaths")
if arcpy.Exists(Scratch + r"\ServiceAreas")==False:
   arcpy.CreateFeatureDataset_management(Scratch,"ServiceAreas")
### CALCULATE SERVICE AREAS FOR MAPS ###
if len(arcpy.ListFields(facilities,"cutoff"))==0:
   arcpy.AddField_management(facilities, "cutoff", "TEXT")
   arcpy.management.CalculateField(facilities, "Per50", "np.around(!Per50!,2)", "PYTHON3", "import numpy as np")
   arcpy.management.CalculateField(facilities, "Per62", "np.around(!Per62!,2)", "PYTHON3", "import numpy as np")
   arcpy.management.CalculateField(facilities, "Per75", "np.around(!Per75!,2)", "PYTHON3", "import numpy as np")
   arcpy.management.CalculateField(facilities, "cutoff", '"{} {} {}".format(!Per50!,!Per62!,!Per75!)', "PYTHON3", None)
   print("Create a new service area")
## INITIALIZE THE ANALYSIS ###
## SET PROPERTIES ###
ServArea.distanceUnits = arcpy.nax.DistanceUnits.Kilometers
## LOAD THE INPUTS ###
fm_sa["Breaks"].mappedFieldName = "cutoff"
whereclause = "cutoff <> 'None None None'"
fac = arcpy.SelectLayerByAttribute_management(facilities,"NEW_SELECTION", whereclause)
arcpy.CopyFeatures_management(fac, Scratch + r"\fac_p")
## SOLVE THE ANALYSIS ###
result_sa.export(arcpy.nax.ServiceAreaOutputDataType.Facilities,gdb + "\FinalAnalysis\SrvArea_Facil")
# Export the results to a feature class
if result_sa.solveSucceeded:
   result_sa.export(arcpy.nax.ServiceAreaOutputDataType.Polygons,gdb + "\FinalAnalysis\SrvArea_Final")
else:
   arcpy.AddMessage("Solved failed")
   arcpy.AddMessage(result_sa.solverMessages(arcpy.nax.MessageSeverity.All))
AndrewClark2
New Contributor III
Here is the error:
Running script Service ARea Testing...
Solved failed
[[30194, 'Data values longer than 128 characters for field [Facilities:Breaks_Meters] are truncated.'], [30024, 'Solve returned a failure.'], [-2147200977, 'Invalid break values.']]
Completed script Service ARea Testing...
The issue is that there are no long fields as I truncated the values to 2 decimal places. The longest current format is 14 characters long. So something weird is going on.
