How do I add feature layers to map through python?
8424
6
07-17-2019 08:29 PM
AndrewClark2
New Contributor III
I am working in ArcGIS Pro 2.4. I am trying to create map layouts automatically through a Python Tool, which is located in a toolbox. I have been able to create this in Jupyter but the people that will be running the tool do not have access to the software. I have the following code at the moment:
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps("Map")[0]
lyt = aprx.listLayouts("Child Care Need Index")[0]
lyrfile = arcpy.mp.LayerFile(path + "/LayerFiles/Neighbourhoods.lyrx")
m.addDataFromPath(lyrfile)
It runs perfectly if I copy and paste it into the python window, but as soon as I try to run it through the toolbox I get the following error message:
File "C:\users\*****\appdata\local\temp\arcgisprotemp11624\mapping.py", line 32, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\_mp.py", line 1531, in addDataFromPath
return convertArcObjectToPythonObject(self._arc_object.addDataFromPath(*gp_fixargs((data_path,), True)))
RuntimeError
Failed to execute (Script1).
Any ideas on what I am doing wrong?
Thanks!
Andrew
DanPatterson_Retired
That leads me to believe that it is the parameters of the toolbox.  If you created a conventional toolbox,
What is a script tool?—Geoprocessing and Python | ArcGIS Desktop
then the problem may be with the toolbox itself or how the parameters (or lack of them) are defined for the toolbox.
If you are using a python toolbox (*.pyt) then there is a load more you have to handle.
Although somewhat dated, the principles described here are largely the same
/blogs/dan_patterson/2016/05/19/toolbox-creation-in-arcgis-pro
To make it easier for the user, you can set Defaults and provide Value lists for user selection.
what is 'path'?
AndrewClark2
New Contributor III
Just the location of my layer file that I define earlier.
Andrew, so can we assume that you imported arcpy?  You say the people don't have the software.... what software are they missing? Pro?  Jupyter?
AndrewClark2
New Contributor III
Yes I imported arcpy. It doesn't matter what they are missing... sorry that was useless details regarding my issue. I am just trying to make my tool as "idiot proof" as possible, which requires to create a standalone toolbox that uses a syntax to create preset maps from existing data.
This exact code works when I use Jupyter, but when I try to create a python script tool for a toolbox I am creating in ArcGIS PRO the same code no longer works. I can even run it in the python window in pro and it works fine. I just don't understand why it crashes when using a toolbox vs the other two methods of running code.
AndrewClark2
New Contributor III
Thanks Dan!!! I got it working. Here is the full syntax and parameters:
import arcpy, os
arcpy.CheckOutExtension("network")
arcpy.env.overwriteOutput = True
path = arcpy.GetParameterAsText(0)
gdb = arcpy.GetParameterAsText(1)
nds = arcpy.GetParameterAsText(3)
nd_layer_name = "Routing_ND"
input_facilities = arcpy.GetParameterAsText(4)
Scratch = arcpy.GetParameterAsText(2)
SA_ChildCare = Scratch + "/SA_ChildCare"
SA_CCLoc_Final = Scratch + "/SA_ChildCare_Final"
people = arcpy.GetParameterAsText(5)
people_pt = gdb + "/Boundary/people_pt"
SA_Population = Scratch + "/SA_Population"
SA_PopLoc_Final = Scratch + "/SA_Population_Final"
CC_Pop_Inter = Scratch + "/cc_pop_i"
ChildCare_Summary = Scratch + "/cc_sum"
CC_Pop_Sum = Scratch + "/cc_pop_sum"
E2SFCA_temp = Scratch + "/E2SFCA_temp"
DA_Summary = Scratch + "/DA_sum"
E2SFCA = gdb + "/FinalAnalysis/E2SFCA"
Z_Summary = Scratch + "/Z_Summary"
m = aprx.listMaps(arcpy.GetParameter(5))[0]
lyt = aprx.listLayouts(arcpy.GetParameter(6))[0]
lyrfile = arcpy.GetParameter(7)
m.addLayer(lyrfile)
Here is the parameters:
