Help with writing python code to stop a script if an external table isn't complete
11032
27
09-08-2021 11:23 AM
ABishop
I am working in ArcGIS Pro 2.8.2.  I am not a professional programmer.  I have been writing python code for about a year and a majority of it comes from script I export and piece together using geoprocessing tools and models in ArcGIS Pro. I have written a series of scripts which run automatically at night to update our SDE and also dependent services which serve web maps/apps to the public.  The issue is that one of the data sources that assists with these updates is a .csv file created from a batch script that is ran from our CAMA system.  Sometimes this batch script doesn't work properly and the file doesn't have complete data which causes all of my scripts to generate files that aren't valid and then consequently, our web maps/apps fail the next day.
What can I add my python scripts to stop running if the source data is incomplete?  How would I go about doing this?  Any advice is greatly appreciated!
Amanda Bishop, GISP
ABishop
@JoeBorgione
I tried the following script and it did not work.  Please tell me what I'm doing wrong.  Does the .csv file have to be a .txt?  Does it have to be set in a variable instead of a file path?
#import arcpy module
import arcpy, os, sys
from arcpy import env
env.workspace = r"K:\GIS_UPDATE\DATA\EXTRACTVIEWS"
env.overwriteOutput = True
startTime = time.perf_counter()
# Opening a file
file = open("K:\AMANDA\Merlin226Data\MCPA226Data1.csv","r") # this opens txt file read only
Counter = 0 # sets the Counter variable to 0 (zero)
# Reading from file
Content = file.read() # sets another variable called Contente and reads
# everything from the read only file you just
#opened
CoList = Content.split("\n") #sets yet another variable called CoList; when
# the file is open and read, it's all in one
#line. This splits each record at the new line
for i in CoList:
if i:
Counter += 1
# this for loop just plows through all the records and each time there is a
# new record, the counter variable increases by one. At the end of the for
# loop, Counter is equal to the number of records.
if Counter < 250000:
exit
#MCPA226Data to Merlin226 Extract-----------------------------------------------------------------
arcpy.conversion.TableToTable(r"K:\AMANDA\Merlin226Data\MCPA226Data.csv", r"K:\GIS_UPDATE\DATA\EXTRACTVIEWS\EXTRACTVIEWS.gdb", "MCPA226DataTEST", '', r'PARCEL "PARCEL" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,PARCEL,0,8000;ALT_KEY "ALT_KEY" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ALT_KEY,-1,-1;PC "PC" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,PC,-1,-1;HX "HX" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,HX,0,8000;AG "AG" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,AG,0,8000;ADD_1 "ADD_1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ADD_1,0,8000;ADD_2 "ADD_2" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ADD_2,0,8000;ADD_3 "ADD_3" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ADD_3,0,8000;ADD_4 "ADD_4" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ADD_4,0,8000;ADD_5 "ADD_5" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ADD_5,0,8000;ZIP "ZIP" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ZIP,0,8000;SITUS_1 "SITUS_1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SITUS_1,0,8000;SITUS_2 "SITUS_2" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SITUS_2,0,8000;MILL_GRP "MILL_GRP" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MILL_GRP,-1,-1;NABRHD "NABRHD" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,NABRHD,-1,-1;BK1 "BK1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,BK1,0,8000;PG1 "PG1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,PG1,0,8000;MO1 "MO1" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MO1,-1,-1;YR1 "YR1" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,YR1,-1,-1;Q1 "Q1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,Q1,0,8000;VI1 "VI1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,VI1,0,8000;INST1 "INST1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,INST1,0,8000;PR_1 "PR_1" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,PR_1,-1,-1;MAP_NBR "MAP_NBR" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MAP_NBR,-1,-1;TWP "TWP" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TWP,-1,-1;RGE "RGE" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,RGE,-1,-1;SEC "SEC" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SEC,-1,-1;ACRES "ACRES" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ACRES,-1,-1;LND1 "LND1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LND1,0,8000;LND2 "LND2" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LND2,0,8000;LND3 "LND3" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LND3,0,8000;ZONE1 "ZONE1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ZONE1,0,8000;ZONE2 "ZONE2" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ZONE2,0,8000;ZONE3 "ZONE3" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ZONE3,0,8000;BLDS "BLDS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,BLDS,-1,-1;WALL "WALL" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,WALL,-1,-1;AGE "AGE" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,AGE,-1,-1;COND "COND" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,COND,-1,-1;ARCH "ARCH" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ARCH,0,8000;USE_SF "USE_SF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,USE_SF,-1,-1;YRBLT1 "YRBLT1" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,YRBLT1,-1,-1;QUAL1 "QUAL1" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,QUAL1,-1,-1;TYPE1 "TYPE1" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TYPE1,0,8000;POOL "POOL" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,POOL,0,8000;STRY "STRY" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,STRY,0,8000;BLD1_SF "BLD1_SF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,BLD1_SF,-1,-1;WELL "WELL" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,WELL,0,8000;SEPTIC "SEPTIC" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SEPTIC,0,8000;ASSD_VAL "ASSD_VAL" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ASSD_VAL,-1,-1;TOT_VAL "TOT_VAL" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_VAL,-1,-1;TOT_LND_VA "TOT_LND_VA" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_LND_VA,-1,-1;TOT_BLD_VA "TOT_BLD_VA" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_BLD_VA,-1,-1;TOT_MISC_V "TOT_MISC_V" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_MISC_V,-1,-1;TOT_TAX_VA "TOT_TAX_VA" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_TAX_VA,-1,-1;TOT_TAXES "TOT_TAXES" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,TOT_TAXES,-1,-1;APP_DATE "APP_DATE" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,APP_DATE,-1,-1;APP_ID "APP_ID" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,APP_ID,-1,-1;SOS "SOS" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SOS,0,8000;SU "SU" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SU,0,8000;HX_YR "HX_YR" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,HX_YR,-1,-1;STR "STR" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,STR,-1,-1;GRP "GRP" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,GRP,-1,-1;CITY "CITY" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,CITY,-1,-1;VM "VM" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,VM,-1,-1;CF "CF" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,CF,0,8000;CL_VAL "CL_VAL" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,CL_VAL,-1,-1;N_CONS "N_CONS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,N_CONS,-1,-1;MKT_ADJ "MKT_ADJ" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MKT_ADJ,-1,-1;DATE_CREAT "DATE_CREAT" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,DATE_CREAT,-1,-1;DATE_L_UPD "DATE_L_UPD" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,DATE_L_UPD,-1,-1;B_UP "B_UP" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,B_UP,-1,-1;PPAR "PPAR" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,PPAR,0,8000;RESUSESF "RESUSESF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,RESUSESF,-1,-1;RESTOTSF "RESTOTSF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,RESTOTSF,-1,-1;COMUSESF "COMUSESF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,COMUSESF,-1,-1;COMTOTSF "COMTOTSF" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,COMTOTSF,-1,-1;RESBLDS "RESBLDS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,RESBLDS,-1,-1;COMBLDS "COMBLDS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,COMBLDS,-1,-1;LAVALUE "LAVALUE" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LAVALUE,-1,-1;MRKT_AREA "MRKT_AREA" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MRKT_AREA,-1,-1;BEDS "BEDS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,BEDS,-1,-1;BATHS "BATHS" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,BATHS,-1,-1;GARAGE "GARAGE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,GARAGE,0,8000;FIRE "FIRE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,FIRE,0,8000;LOCOBS "LOCOBS" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LOCOBS,-1,-1;FUNCOBS "FUNCOBS" true true false 8 Double 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,FUNCOBS,-1,-1;SEC_5 "SEC_5" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SEC_5,0,8000;LANDREV "LANDREV" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,LANDREV,0,8000;NBRUNITS "NBRUNITS" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,NBRUNITS,-1,-1;MH "MH" true true false 4 Long 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,MH,-1,-1;RTE "RTE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,RTE,0,8000;HXUNDELIVERABLE "HXUNDELIVERABLE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,HXUNDELIVERABLE,0,8000;ROADTYPE "ROADTYPE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,ROADTYPE,0,8000;SUBTYPE "SUBTYPE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SUBTYPE,0,8000;SINKHOLE "SINKHOLE" true true false 8000 Text 0 0,First,#,K:\AMANDA\Merlin226Data\MCPA226Data.csv,SINKHOLE,0,8000', '')
print("Merlin226Data to Merlin226DataTEST extract completed")
endTime = time.perf_counter()
elapsedTime = round((endTime - startTime) / 60, 2)
print("Script finished in {0} minutes".format(elapsedTime))
Amanda Bishop, GISP
MichaelVolz
Esteemed Contributor
Amanda:
Do you have any communication with the admin of the original csv file?  I ask because how would you know the data errors would be fixed the next time to try to run the script.  Maybe it would be more proactive to trap the errors and let the csv admin personnel fix the data based on you errors you trapped in your code.
ABishop
@MichaelVolz
Hi.... I do have communication with the admin of the original .csv file. The issue is that the batch process she has running to create the .csv is coming from our CAMA database and she said it is very complicated to recreate or even troubleshoot.  I don't think she has much experience with it because she just took over as our IT Director.  Anyway, I am doing what I can to mitigate the issues because, as you can imagine, I have spent a log of time and effort creating all of my tasks to make this work and when her file doesn't get created properly, well... then it reflects poorly on me because none of my tasks work. SMH
Amanda Bishop, GISP
JoeBorgione
replace with:
file = open(r"K:\AMANDA\Merlin226Data\MCPA226Data1.csv","r")
Use r to specify 'raw' text to the python interpreter.  Otherwise you have to escape those slashes in your path like this:
file = open("K:\\AMANDA\\Merlin226Data\\MCPA226Data1.csv","r")
I'm lazy and forgetful so when it comes to paths I always use r"C:\blah\blah\blah" so I don't have to remember which slash to use.
Also, you'll notice I'm using a code window to past my python into.  Expand the menu bar by clicking on the three dots; click on the </> symbol and choose python from the drop down list.  Paste your code there.  It makes it much easier for us to read and/or trouble shoot...
ABishop
@JoeBorgione
Thank you again.  I will attempt to implement this morning and update you as soon as I get a result.  Also, thanks for the tip on how to insert the python script in this message.  I will definitely use this for the future!  You are awesome!
Amanda Bishop, GISP
ABishop
@JoeBorgione
I tried to implement the script below this morning and it didn't exit, it continued to extract the table anyway.  Any more suggestions?
# Opening a file
file = open(r"K:\AMANDA\Merlin226Data\MCPA226Data.csv","r")  # opens file read only
# Reading from file
Content = file.read()       # sets another variable called Content and reads
                            # opened
                             #the file is open and read, it's all in one
for i in CoList:
    if i:
        Counter += 1
   exit
#input('Press ENTER to exit')
Amanda Bishop, GISP
MichaelVolz
Is there a chance that the counter is never getting to 250000?  Why not set it at a much lower value and print out what the counter is at right before the program exits as it might be doing something unexpected at this point?  This would only be needed for trouble-shooting purposes.
JoeBorgione
I may have lead you astray.  At line 29, use the exit() method like this:
if blah blah blah:
  exit()
More reading for you.
ABishop
@JoeBorgione
OK... so I did what you suggested with the exit () and it worked I think... I got this message console pop up (see attached pic).  Anyway to bypass?
Amanda Bishop, GISP
JoeBorgione
@ABishop   Exiting/quitting etc in python can be a little weird.  I don't get that message when I run the exit() method in Spyder, but I do in what you seem to be using, IDLE.  You may want to check the other options available to you in that link I posted earlier.
I just tried this in an idle window and don't get the prompt:
import sys
for i in range(0,10):
    if i == 5:
        sys.exit()
