GIS tutorial for Python Scripting written by David Allen
3568
12
09-17-2014 06:05 PM
Jeremiah_OlatundeGbolagun
Please let me know if the below code is right or not. if it is wrong can you please correct it for me.
I changed the below code from the above titled book during learning Tutorial 1, which was titled "Use Python in the Label Expression dialog box". I am using ArcGIS 10.1 but the tutorial used ArcGIS 10.2.
This is the original code from the text book.
def FindLabel ( [OwnerName] 😞
  rawName = [OwnerName]
  commaNum = rawName.find(",")
  formatName = rawName[commaNum+2:] + " " + rawName[:commaNum]
  return formatName
When I run this above code I have this error "SyntaxError: invalid syntax (<string> , line 4"
Can you please let me know the right code to use.
I modify it to below code but still experience another error.
  formatName = rawName(commaNum[2:]) + " " + rawName(commaNum[0:]
  return formatName
Regards,
Jeremiah.
JaredStewart
Hi Curtis,
Clicking on your blog link directs me to a page with the following message:
Access to this place or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.
curtvprice
Thanks for letting me know...  I moved my blog out of the python space to my personal space. It should be accessible by everyone now.
JaredStewart
Excellent, thank you! That is a very handy tip!
