File already exists after file was just created. Code in attached picture
3173
12-07-2020 10:50 AM
SharitaU
Generic Parameters: Table X (where the latitude value of some records are 0 while other records have a latitude of roughly -88) and Folder A
Program Goal: If folder A does not exist, create folder A, geocode just the records of table X where latitude is 0 and store the resulting shapefile in folder A. If folder A does exist, delete folder A, create folder A, geocode just the records of table X where latitude is 0 and store the resulting shapefile in folder A.
My code actually does everything I need it to do. The problem is however is that regardless of whether folder A existed previously or whether it was just created, once my file is geocoded and saved to folder A, my program throws error 000725 "Output feature class already exists". I don't understand why I'm running into this problem since the output feature class was just created. Even the time stamps of the files are accurate so I know I'm not looking at an old version of the shapefile.
Help is greatly appreciated. Thanks in advance
DanPatterson
MVP Esteemed Contributor
The preview doesn't work (may be tied up in internal checks).
Enter the code between the code blocks by clicking on the . . . and selecting the </> and insert your code.
In any event, you should set the ability to overwriteOutputs and use the "Exists" check.
Checking for the existence of data—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
