def fix(oldApn): if '-' not in oldApn: newApn = '' else: apnList = oldApn.split('-') if len(apnList) == 3: newApn = apnList[0].lstrip() + '-' + apnList[1].lstrip + '-' + apnList[2].zfill(2) else: newApn = apnList[0].lstrip() + '-' + apnList[1].lstrip return newApn
Here's how I would do it, using lists and list comprehensions...
def fix(oldApn):
# find integer pieces in "-" delimited string, skipping zeros
pieces = [str(int(p)) for p in oldApn.split("-") if p.isdigit()]
newApn = "-".join([p for p in pieces if p != "0"])
return newAPn
