ExtractMultiValuesToPoints Fails in standalone script
1207
6
07-29-2021 05:01 PM
GabrielMarcus_C
New Contributor III
I'm running AGP 2.8.0 with the default python environment.
I can execute the same script fine through the toolbox, but if I schedule it for a later time, or run it in the IDE it fails with the error below.
Error Info:
ERROR 160326: The table already exists.
Failed to execute (ExtractMultiValuesToPoints).
When I look this error up, under the Solution it says "There is no documented solution at this time."
I have env.overwriteOutput=True, but I also go through and check for the field names that are generated and delete them before I get to this step in the script.
GabrielMarcus_C
New Contributor III
This error went away when I commented out the Definition Query for the point file.
The help isn't helpful at all.
"While this error can occur, it occurs so rarely that the typical causes have not been identified so no solution is available at this time."
DavidPike
MVP Frequent Contributor
Are you able to share your script? I think that's the only way forward.
GabrielMarcus_C
New Contributor III
import arcpy, os
from arcpy.ia import *
from arcpy.sa import *
from arcpy import env
import pandas as pd
import sys
import traceback
# Check out the ArcGIS Spatial Analyst extension license
arcpy.CheckOutExtension("Spatial")
#####   Script Variables
aprx = arcpy.mp.ArcGISProject(r"C:\Users\Devel\Aug2021Wx\Aug2021Wx.aprx")
adm = r"C:\Geodata\Locations.gdb"
cLocs = os.path.join(adm, "Locations2021")
NDFDOutConus = r"C:\ndfd\degrib\output\conus"
wspd = os.path.join(NDFDOutConus,"wspd.nc")
wgust = os.path.join(NDFDOutConus,"wgust.nc")
snow = os.path.join(NDFDOutConus,"snow.nc")
rain = os.path.join(NDFDOutConus,"qpf.nc")
ice = os.path.join(NDFDOutConus,"iceaccum.nc")
mint = os.path.join(NDFDOutConus,"mint.nc")
maxt = os.path.join(NDFDOutConus,"maxt.nc")
apt = os.path.join(NDFDOutConus,"apt.nc")
locFile = cLocs.split("\\")[-1]
aprxMap = aprx.listMaps("Map")[0]
env.workspace = r"C:\Users\Devel\Aug2021Wx"
arcpy.env.overwriteOutput = True
def exec():
    # wind Speed
    out_multidimensional_raster_wspd = arcpy.ia.AggregateMultidimensionalRaster(wspd, "StdTime", "MAXIMUM",        "WindSpd_10_HTGL", "ALL", '', None, '',        None, '', "DATA")
    out_multidimensional_raster_wspd.save("wspd_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved windspeed")
    # wind gusts
    out_multidimensional_raster_wgust = arcpy.ia.AggregateMultidimensionalRaster(wgust, "StdTime", "MAXIMUM",
        "WindGust_10_HTGL", "ALL", '', None,
    out_multidimensional_raster_wgust.save("wgust_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved windgusts")
    # Snow
    out_multidimensional_raster_snow = arcpy.ia.AggregateMultidimensionalRaster(snow, "StdTime", "SUM", "SnowAmt_SFC",
    out_multidimensional_raster_snow.save( "snow_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved snow")
    # Rain
    out_multidimensional_raster_qpf = arcpy.ia.AggregateMultidimensionalRaster(rain, "StdTime", "SUM", "QPF_SFC", "ALL",
    out_multidimensional_raster_qpf.save( "qpf_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved QPF")
    # Ice
    out_multidimensional_raster_ice = arcpy.ia.AggregateMultidimensionalRaster(ice, "StdTime", "SUM", "IceAccum_SFC",
    out_multidimensional_raster_ice.save( "iceaccum_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved ice")
    # Min Temp
    out_multidimensional_raster_mint = arcpy.ia.AggregateMultidimensionalRaster(mint, "StdTime", "MINIMUM",
        "MinT_2_HTGL", "ALL", '', None, '',
        None, '', "DATA")
    out_multidimensional_raster_mint.save( "mint_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved Min T")
    # Max Temp
    out_multidimensional_raster_maxt = arcpy.ia.AggregateMultidimensionalRaster(maxt, "StdTime", "MAXIMUM",
        "MaxT_2_HTGL", "ALL", '', None, '',
        None, '', "DATA")
    out_multidimensional_raster_maxt.save( "maxt_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved Max T")
    out_multidimensional_raster_apt = arcpy.ia.AggregateMultidimensionalRaster(apt, "StdTime", "MAXIMUM",
        "ApparentT_2_HTGL", "ALL", '', None, '',
        None, '', "DATA")
    out_multidimensional_raster_apt.save("apt_Aggregate.crf")
    arcpy.AddMessage("Loaded and saved apt")
def extractFields():
    inRasterList =  [["wspd_Aggregate.crf", "WindSpeed"],
                    ["wgust_Aggregate.crf", "WindGust"],
                    ["snow_Aggregate.crf", "Snow"],
                    ["qpf_Aggregate.crf", "QPF"],
                    ["iceaccum_Aggregate.crf", "Ice"],
                    ["mint_Aggregate.crf", "minT"],
                    ["maxT_Aggregate.crf", "maxT"],
                    ["apt_Aggregate.crf", "apt"]]
    arcpy.AddMessage("Dropping old fields...")
    # checking to see if the weather value fields are already in the table
    dropFields = []
    field_names = [f.name for f in arcpy.ListFields(cLocs)]
    for d in field_names:
        if d in ["WindSpeed", "WindGust", "Snow", "QPF", "Ice", "minT", "maxT","apt"]:
            dropFields.append(d)
            arcpy.AddMessage("Found {}".format(d))
    if len(dropFields) > 0:
        arcpy.DeleteField_management(cLocs, dropFields)
    arcpy.AddMessage("Multi Values to Points...")
    for m in aprxMap.listLayers(locFile + "*"):
        if m.supports("DEFINITIONQUERY"):
            m.definitionQuery = ""
            m.definitionQuery = "CTRY = 'US'"
    try:
        arcpy.env.extent = "MINOF"
        arcpy.sa.ExtractMultiValuesToPoints(cLocs, inRasterList, "NONE")
        arcpy.AddMessage("Successfully completed!")
    except Exception as e:
        e = sys.exc_info()[1]
        arcpy.AddError(e.args[0])
        print(e.args[0])
        # Get the traceback object
        tb = sys.exc_info()[2]
        tbinfo = traceback.format_tb(tb)[0]
    finally:
        arcpy.CheckInExtension("Spatial")
if __name__ == "__main__":
    exec()
    extractFields()
GabrielMarcus_C
New Contributor III
I'm running the same script from the toolbox and scheduling it to run. It just fails on the scheduled attempts. I initially thought that it was something with paths not being fully written out, but I don't think that's the case.
A few things:
  • I don't use concurrent licensing, so checking in/out the spatial license should have no effect
  • The NetCDF files are from the tkdegrib program produced by the National Weather Service. I download the data before running the script.
  • The point file is just points, not multipoint. Definition query is set to just the US and then to nothing.
Thanks!
YuWang1
Hello. Thank you so much for your post about Extract Multivalues to Point. I am a Product Engineer on the Spatial Analyst team. We'd like to reproduce this issue and then try to solve it. Is it possible for us to get a copy of the data you used in this process?
GabrielMarcus_C
New Contributor III
by Anonymous User
Not applicable
What if you try changing the definition queries using the updateDefinitionQueries() on the layer to be alittle more explicit?
Stepping through the process,
Only deactivates the previously active definition query, but keeps the query in the def query list and maybe(?) it's causing a conflict that throws the error.
for m in aprxMap.listLayers():
        print(f'existing dq: {m.listDefinitionQueries()}')
        # existing dq: []
        m.definitionQuery = "OBJECTID = 1"
        print(f'dq set: {m.listDefinitionQueries()}')
        # -> dq set: [{'name': 'Query 1', 'sql': 'OBJECTID = 1', 'isActive': True}]
        print(f'dq set to "": {m.listDefinitionQueries()}')
        # -> dq set to "": [{'name': 'Query 1', 'sql': 'OBJECTID = 1', 'isActive': False}]
        updte = [] # <- set to empty list to clear the previous def query or # <- set to empty list or [{'name': 'Query 1', 'sql': 'OBJECTID = 2', 'isActive': True}] as new def query
        df_done = m.updateDefinitionQueries(updte)
        print(f'dq set by update: {m.listDefinitionQueries()}')
        # -> dq set by update: []
