Export multiple tables in GDB to Excel with a new sheet for each table
5234
11
05-16-2018 09:05 AM
Brian_McLeer
Occasional Contributor II
Researching to see if there is a way to use Python to export multiple tables in a File Geodatabase to a single Excel file. I would like for each sheet name to have the same name as the table.
My current situation is that I ran a Python script to take all the domains a GDB and create a table within the GDB.
The article referenced from:
https://community.esri.com/thread/163889
def main():
 import arcpy, os
 gdb = r"Z:\GIS_Projects\zUpdatesBrian\Scripts\ListDomains\ListDomains.gdb"
 arcpy.env.overwriteOutput = True
 for dom in arcpy.da.ListDomains(gdb):
 if dom.domainType == 'CodedValue':
 arcpy.DomainToTable_management(in_workspace=gdb,
 domain_name=dom.name,
 out_table=os.path.join(gdb, dom.name),
 code_field="item",
 description_field="descrip",
 configuration_keyword="")
 print " - domain '{0}' of type '{1}' exported to table".format(dom.name, dom.domainType)
 else:
 print " - domain '{0}' of type '{1}' skipped".format(dom.name, dom.domainType)
if __name__ == '__main__':
 main()
Brian
JoeBorgione
I'm in the same boat: I have multiple tables in a fgdb and would like to export them to a workbook as individual worksheets. Just moments ago, I installed the xlsxwriter module as a package in ArcGIS Pro.  That's the easy part.  Now I'm working on figuring it out.  See: Getting Started with XlsxWriter — XlsxWriter Documentation   ( I just create my Hello.xls...)
Hey Dan, Joshua or Curtis- ever work with xlsxwriter?
Dan Patterson
Joshua Bixby
Curtis Price
That should just about do it....
DanPatterson_Retired
yes ... but not tonight
JoeBorgione
JoshuaBixby
MVP Esteemed Contributor
JoeBorgione
Thanks.  I'll take a look in the morning.
JoeBorgione
Getting pretty close, but not quite there.  For some reason, I can only get pandas to write one of my tables out to the target excel spreadhheet, and that depends on where I put writer.save() function:
import pandas as pd
import arcpy
from arcpy import env
fields = ['TaxingEntity', 'ProjectID']
targetXL = r'J:\RDA\junk.xls'
arcpy.env.workspace = r'J:\RDA\Temp2.gdb'
#tables = arcpy.ListTables()
tables = ['Project101','Project102', 'Project103' ]
for table in tables:
    if table == 'AllTables_5_16':
        pass
    elif table == 'NeedTaxEntRecords':
        pass
    elif table == 'BlakesTaxinEntities':
        pass
    else:
        inTable = table
        print (table)
        tableArray = arcpy.da.TableToNumPyArray(inTable,fields)
        print (tableArray)
        writer = pd.ExcelWriter(targetXL)
        df = pd.DataFrame(data=tableArray)
        df.to_excel(targetXL,table)
        writer.save()
        del df
 In this example of my code, I'm only working with 3 of the 100+ tables which is why line 8 is commented and line 9 creates a list of table names.  The problem child seems to be line 25 writer.save(): at it's current location inside the for loop, I only get Project101 written to the target, and I get an error:
IndexError: list index out of range
If I comment it out or put it outside the for loop, I don't get any errors, but I only get Project 103 to get written to the target.
Perhaps a second (or third) set of eyes might see what the issue could be?
Joshua Bixby
Dan Patterson
JoshuaBixby
My guess is this line is messing it up:
Instead of passing the XLS file path, try passing the writer itself.
JoeBorgione
Following pandas.DataFrame.to_excel — pandas 0.23.0 documentation , it shows:
>>> writer = pd.ExcelWriter('output.xlsx')
>>> df1.to_excel(writer,'Sheet1')
>>> df2.to_excel(writer,'Sheet2')
>>> writer.save()
However, when I use 'writer' as shown in lines 1 & 2 (line 24 in my script) the target excel work book does get created at all. However, when I use targetXL , it does get created,with only one sheet.  Weird....
When I take the process out of the loop, and only work with 1 table it works as you and the documentation suggests:
import pandas as pd
import arcpy
table = 'Project101'    # just one, not a list now....
inTable = table
df = pd.DataFrame(tableArray)
df.to_excel(writer,table)
writer.save()
When I put print() functions in along the way, I can see each array, and each subsequent dataframe while in the original loop; again weird.  I'll keep hacking.....
JoeBorgione
Ha.... Got it....  Notice below where I place the writer variable: outside the for loop.  What was happening is the target xls would get re-initialized each time through the loop.  Now that I set it up outside the loop, it runs like a champ!  Fun stuff!  And I'm getting paid for it!
import pandas as pd
import arcpy
targetXL = r'J:\RDA\ToBlake.xls' ##### <- set up the target outside the loop
        pass
        pass
        pass
    else:
        inTable = table
        del tableArray
        del df
        writer.save()
Sorry to hi-jack your thread Brian M‌, but here you go!
