Export feature class based on values from two fields
1830
10-30-2018 11:16 AM
GIS_geek
Good day,
I want to export a feature class to a feature class but only the ones that meet a certain criteria.  I need values from field OWNER that are equal to LB and values from STATUS that are equal to ABN.  I was able to export just one of the fields expression (OWNER) using AddFieldDelimiters, but I am not sure if this allows for an expression pointing to two fields. I tried adding a second field but only OWNER was successful and all values from STATUS were exported.  Here is my script,
# Import system modules
import arcpy
from arcpy import env
# Set the workspace
arcpy.env.workspace = "Database Connections/ADMIN Edit.sde/SewerCollectionNetwork"
ArcSDE = arcpy.env.workspace
env.overwriteOutput = True
# Set local variables
inFeatures = "ssGravityMain"
outputLocation = "C:/Users/Navarro/Desktop/CAD"
outputDatabase = "CCTV.gdb"
outputDatabaseLocation = "C:/Users/Navarro/Desktop/CAD/CCTV.gdb"
outputFeatureClass = "GravityMain"
delimitedOwner = arcpy.AddFieldDelimiters(ArcSDE, "OWNER")
delimitedStatus = arcpy.AddFieldDelimiters(ArcSDE, "STATUS")
expressionOwner = delimitedOwner + " = 'LB'"
expressionStatus = delimitedStatus + " = 'ABN'"
# Creating new .gdb
print("Creating geodatabase")
arcpy.CreateFileGDB_management(outputLocation, outputDatabase)
# Export feature class to geodatabase
print("Exporting feature class to feature class")
arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outputDatabaseLocation,
outputFeatureClass, expressionOwner)
Thank you in advance.
JakeSkinner
Esri Esteemed Contributor
Hi Hector,
You could do the following:
expression = "OWNER = 'LB' AND STATUS = 'ABN'"
outputFeatureClass, expression)
DanPatterson_Retired
You didn't try field mapping?
FieldMappings—ArcPy classes | ArcGIS Desktop
JakeSkinner
Hi Hector,
GIS_geek
Jake,
Thanks for the assistance.
