Error on updateRow or deleteRow
3005
04-14-2016 10:26 AM
SteveClark
New Contributor III
I have relatedtable in sde that I want to insert or update/delete a row. I am able to insertRow fine but I am not able to execute updateRow or deleteRow on the cursor. There is always: SystemError: error return without exception set
Here's the pertinent part of the code:
tableFields = ['LID', 'OperatedBy', 'GPSPositions', 'Turns', 'OperationDate', 'Longitude', 'Latitude', 'HighTorque', 'BeginTime', 'Remarks', 'Position', 'EndTime']
insValues = [u'W.285489', u'Roy P.', None, 88.2, datetime.datetime(2015, 2, 19, 0, 0), None, None, 50, u'11:55 AM', u'PAVD,VAC', u'Open', u'12:00 PM']
if tableCount == 0: # Insert - THIS WORKS FINE
    editor.startOperation()
    with arcpy.da.InsertCursor(tablePath, tableFields) as insCursor:
        insCursor.insertRow(insValues)
    editor.stopOperation()
    saveEdits = True
else: # Update
    with arcpy.da.UpdateCursor(tablePath, tableFields, lidQuery) as updCursor:
        for updRow in updCursor: # ALWAYS RETURNS THE ONE ROW THAT I WANTED TO UPDATE OR DELETE
            updRow = insValues
            updCursor.updateRow(updRow) # - ERROR
            # ALSO JUST UPDATING ONE VALUE - SAME ERROR
            # updRow[0] = 'W.999999'
            # updCursor.updateRow(updRow)
    # OR I could deleteRow and then do an insertRow - SAME ERROR
    #    for updRow in updCursor:
    #        updCursor.deleteRow()
    saveEdits = True
As far as I can tell, the updCursor returns what I want - the row that I want to update or delete. But no matter what I do with that cursor, I get
  File "<pyshell#89>", line 1, in <module>
or simply "error return without exception set"
What am I doing wrong with the UpdateCursor?
(This is ArcMap 10.2.1.)
AdrianWelsh
MVP Honored Contributor
Steve, would it help if you posted the entire segment of code so we can see where different variables are being instantiated?
SteveClark
New Contributor III
Here's the entire code as I have progressed so far:
import arcpy
import os
import sys
import datetime
inputFC = "WLINEVALVE"
try:
    dbConnection = r'Database Connections\conn.sde'
    workspace = os.path.dirname(dbConnection)
    editor = arcpy.da.Editor(workspace)
    saveEdits = False
    editor.startEditing(False, True)
    fcPath = dbConnection + "\\" + inputFC
    tableName = "ARCFM." + inputFC + "RELTABLE_EVW"
    tablePath = dbConnection + "\\" + tableName
    # hardcoding for test
    lidQuery = "{0} = {1}".format("LID", "'W.285489'")
    with arcpy.da.SearchCursor(fcPath, ['*'], lidQuery) as fcCursor:
        try:
            fcLID = fcCursor.next() # will throw StopIteration if empty
            if fcLID != None:
                tableCount = 0
                with arcpy.da.SearchCursor(tablePath, ['*'], lidQuery) as tableCursor:
                    for tableLID in tableCursor:
                        tableCount += 1
                # if no count, do Insert; else do Update
                        del insValues
                    saveEdits = True
                else: # Update
                            updRow = insValues
                        saveEdits = True
            else:
                print 'LID not valid, ignore for now = abort operation'
                editor.abortOperation()
            del fcLID
        except StopIteration:  # if no LID in featureclass
except Exception as ex:
    print 'Error: ' + str(ex) + ' = abort operation'
finally:
    if saveEdits:
        print 'Stop Editing and Save'
        editor.stopEditing(True)
    else:
        print 'Stop Editing and Not Save'
        editor.stopEditing(False)
TomaszTARCHALSKI1
when inserting - I think you need to insert tuple, not the list. Try this one: updCursor.updateRow(tuple(insValues)).
SteveClark
New Contributor III
I updated line 40 in the code above
                            updRow = insValues
                            updCursor.updateRow(tuple(updRow))
and still got the same error.
I wonder what's the difference between insertRow and updateRow when I am using the same insValues list. insertRow works fine but not updateRow.
