Enterprise Geodatabase feature class naming
1929
02-11-2022 07:10 AM
Boyang_Wang
Not sure if this is typical, but whenever I create a feature class in my enterprise geodatabase, its name will have the database and username added. For example, if I create a feature class called FC, its name will become "database.username.FC".
This creates a problem when I try to use python to backup my enterprise geodatabase feature classes using FeatureClassToFeatureClass. I don't want my backup feature class name has "database.username." in it. How can I get the feature class name only without using string manipulation?
Thanks!
KimberlyGarbade
For enterprise GDBs (at least in SQL Server in my case) this is common, but usually its not an issue, although I haven't tried Feature Class to Feature Class backup using a python script.  That being said....
In Python the output name is an input into the Feature Class to Feature Class function:
arcpy.conversion.FeatureClassToFeatureClass(in_features, out_path, out_name, {where_clause}, {field_mapping}, {config_keyword})
So if you have a variable something like txtInFeatures (to use as the 'in_features' in the function reference above) and its value is in the form "DatabaseName.Owner.FeatureClassName", I would use something like this to generate the txtOutName (to use as the 'out_name' in the function reference above)
txtOutName = txtInFeatures[txtInFeatures.rindex('.')+1:]
below is a snip of a test I ran in a python emulator. Code on the left, result on the right.
Hope this helps.
KimberlyGarbade
Hope this helps.
Boyang_Wang
This works great as I can use the same code for different database names and owner names. Thanks!
