Default value of field not accessible via arcpy?
1504
06-23-2014 11:56 AM
KerryAlley
The Python/arcpy field class does not have a defaultValue property!  Is that an oversight, or a deliberate feature of arcpy's field class?  I know the IField interface (ArcObjects) will provide the defaultValue, but using comtypes is a hassle.  Any other way of getting the default field value using Python?
Kerry
BradPosthumus
Occasional Contributor II
It appears they added defaultValue into arcpy in version 10.1, so I assume you're using an earlier version?
BradPosthumus
KerryAlley
Aaaargh!  You're right!  The field.defaultValue *is* a valid property...it just isn't documented in 10.1 or 10.2!!!
I was relying on the documentation for the arcpy field class.  I also tried searching the 10.2 help for "defaultValue," and finally gave up and parsed the default values out of the metadata xml files (ugh!).
I submitted feedback through the Help pages, so hopefully that will be updated.
Kerry
