Decode(Intersects(FeatureSetByName, $feature) -Arcade PopUp
2044
11-01-2023 12:58 PM
Confetti
I am making a popup with arcade for address points. I am running an intersect on a polygon layer and then trying to decode the variable the object is stored in (sel).
var z1 = 'Jimbob'
var z2 = 'Scuba Steve'
var z3 = 'Stranger'
var z4 = 'Pedestrian'
var sel = Intersects(FeatureSetByName($map, "Zones"), $feature)
return (sel)
//return(FeatureSetByName($map, "Zones"))
return Decode(sel, "BZ1", z1, "BZ2", z2, "BZ3", z3, "BZ4", z4, "Scooby")
When I search an address I get the default "Scooby" even though the address is clearly in one of the other code options.
return(sel) shows the following image:BZ3.pngBZ3.png
Confetti
The count suggestion did not work.
The below code gives me a match by matching the FeatureSet object of the intersect to itself-See the Decode(sel,sel, CPDT...)
return Decode(sel, sel, CPDT, "CPZ3", z1, "CPZ2", z2, "CPZ3", z3, "CPZ4", z4, "Address is not in a Greenville Community Police Zone")
Solution: From here I transferred the objects to an array with a loop and then put the sel variable in another array. I then compared object ids.
for (var i in zonez) {
  Insert(arr,0,i);
var arr2 = []
for (var k in sel) {
  Insert(arr2,0,k)
return Decode(arr2[0]['OBJECTID'], arr[3]['OBJECTID'], z1, arr[1]['OBJECTID'], z3, arr[2]['OBJECTID'], z2, arr[4]['OBJECTID'], CPDT, arr[0]['OBJECTID'], z4, "Scooby")
KenBuja
MVP Esteemed Contributor
Intersects returns a FeatureSet, but you need to get the attribute from a single feature to use in your Decode statement.
var z1 = 'Jimbob'
var z3 = 'Stranger'
//return (sel)
return Decode(First(sel).P_ZONE, "BZ1", z1, "BZ2", z2, "BZ3", z3, "BZ4", z4, "Scooby")
Confetti
I assumed that was the case, do you know by what method that is accomplished? Dot notation and bracket notation don't seem to be the way, giving error: Test execution error: Execution error - Cannot access value using a key of this type. Verify test data.
KenBuja
It might be because there are no intersecting features. Does this work?
var z1 = 'Jimbob'
var z3 = 'Stranger'
if (Count(sel) > 0) return Decode(First(sel).P_ZONE, "BZ1", z1, "BZ2", z2, "BZ3", z3, "BZ4", z4, "Scooby")
Confetti
  Insert(arr,0,i);
var arr2 = []
  Insert(arr2,0,k)
