Date return issue with ArcSDESQLExecute
1008
01-07-2021 07:35 AM
CassKalinski
I am converting a script that uses pyodbc for a couple of select statements to using ArcSDESQLExecute instead. The change works fine on most of the data retrieval but I am hitting an issue on a date field in one of the queries.
With pyodbc, the field is returned as a date object. With ArcSDESQLExecute, the date comes back as a string like 'mm/dd/yyyy'. No hours, minutes, etc. I need either a date object (preferred) or a string with the full %Y%m%d%H%M%S format.
Is there a flag I am missing? A change needed in the SQL statement?
* MS SQL data base
* Field is type datetime in the database
* Records are timestamps every ~15 minutes, so having the full date object is important
* Same SQL string used in both pyodbc and ArcSDESQLExecute and it worked fine before the update.
def _get_timeseries_data(start, end, senID):
# start = datetime object
# end = datetime object
DB_TIMESERIES = '[{}].[{}].[timeseries]'.format(DB,SCHEMA)
DB_CONN = r'C:\Users\blah\blah\blah\Connection to 10.20.2.5.sde'
cnx = arcpy.ArcSDESQLExecute(DB_CONN)
# [Timestamp] = table field of type datetime (don't like the naming, but that is from the app vendor)
# Example from db: 2014-11-17 14:49:01.000
sqlString = "SELECT [Timestamp], [RecordedValue], [GradeName], [ApprovalName] \
FROM {} WHERE (SensorID = '{}') AND (Timestamp BETWEEN CONVERT(datetime, '{}') AND CONVERT(datetime, '{}'))\
ORDER BY Timestamp"\
.format(DB_TIMESERIES, senID, start, end)
rows = cnx.execute(sqlString)
logging.debug('TS query row: %s', row)
dRows = []
for row in rows:
    dRows.append([row[0], row[1], row[2], row[3]])
del cnx
return dRows
BlakeTerhune
MVP Regular Contributor
Try formatting the date in the SQL when you query it. Here's your query string but formatted with Python multiline string.
sqlString = """SELECT FORMAT([Timestamp], 'yyy-MM-dd HH:mm:ss.fff') as Timestamp,
  FROM {}
  AND (
  ORDER BY Timestamp
""" .format(DB_TIMESERIES, senID, start, end)
Sorry, I work with Oracle databases so I apologize if something in that syntax is slightly off.
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community would help readability
... sort of retired...
BlakeTerhune
  FROM {}
  AND (
  ORDER BY Timestamp
CassKalinski
Excellent! Worked as advertised.
Thank you Blake!
CassKalinski
The actual code snippet then...
    dRows = []
    try:
        for row in rows:
            # With pyodbc, used fTimestamp instead of row[0] in the append...
            # fTimestamp = row.Timestamp.strftime("%Y-%m-%d %H:%M")
            fValue = _format_readings(row[1])
                fValue,
                row[2],
                row[3]])
    except Exception as e:
        print('SQL call failed. SQL: %s. Error: %s', sqlString, e)
    del cnx
    return dRows
