Creating a Function with an Update Cursor
2071
8
04-08-2021 02:52 PM
TatjanaScagliotti
I have an update cursor that updates rows of a feature class on AGOL. The code below works.
with arcpy.da.UpdateCursor (fc, ['OBJECTID_1', 'Wk4_March29April1_ACTIV','Wk4_HRS', 'Wk5_April5April8_ACTIV','Wk5_HRS'], "Wk4_March29April1_ACTIV LIKE '%Planned%'") as cursor:
    for row in cursor:
        row[3] = row[1]
        row[4] = row[2]
        row[1] = None
        row[2] = None
        cursor.updateRow(row)
I'm now trying to turn this code into a function so I don't have to keep hard coding the values. However, the function I've made isn't working when I call it and pass in the variables I want to use. The code below is the function.
def weekly_update(week_a, hours_a, week_b, hours_b):
     with arcpy.da.UpdateCursor (fc, ['OBJECTID_1', 'week_a','hours_a', 'week_b','hours_b'], "week_a LIKE '%Planned%'") as cursor:
        for row in cursor:
            row[3] = row[1]
            row[4] = row[2]
            row[1] = None
            row[2] = None
#call the function and pass in the variables
weekly_update("Wk25_Oct12Oct15_ACTIV", "Wk25_HRS", "Wk26_Oct19Oct22_ACTIV", "Wk26_HRS")
This is the error I keep getting
RuntimeError: A column was specified that does not exist. [week_a]
Any suggestions would be great. Thanks!
RandyBurton
MVP Alum
@JoeBorgioneand @Anonymous User  offer good solutions.  But you also need to use the  proper form in your query since 'week_a' is a variable name and not the actual field name.
     with arcpy.da.UpdateCursor (fc, ['OBJECTID_1', week_a,hours_a, week_b,hours_b], "{} LIKE '%Planned%'".format(week_a)) as cursor:
Or, with Jeff's idea:
fldList = ["Wk25_Oct12Oct15_ACTIV", "Wk25_HRS", "Wk26_Oct19Oct22_ACTIV", "Wk26_HRS"]
def weekly_update(fldList):
     with arcpy.da.UpdateCursor (fc, fldList, "{} LIKE '%Planned%'".format(fldList[0])) as cursor:
JoeBorgione
Try removing the quotes around your parameter-variable names. When you enclose them like that the cursor is looking for a field of those names instead of the value of the variables.
TatjanaScagliotti
Unfortunately, that doesn't work.
by Anonymous User
Not applicable
Joe is correct. ...An alternative that might help keep variables and parameter assignments from getting tangled is to just pass a list of the fields like:
        for row in cursor:
            row[3] = row[1]
            row[4] = row[2]
            row[1] = None
            row[2] = None
BlakeTerhune
MVP Regular Contributor
This is a good solution. Just be aware @TatjanaScagliotti that if you don't pass the right number of fields, the field assignment will error out. You could validate the fldList argument before opening the cursor to make sure it's got four items.
assert len(fldList) == 4, "fldList must have exactly 4 field names; like week_a, hours_a, week_b, hours_b"
TatjanaScagliotti
Thank you, I like the idea of using a list and having an assert statement.
RandyBurton
MVP Alum
TatjanaScagliotti
Thank you,  the .format() is exactly what I needed.
JoeBorgione
(fc, ['OBJECTID_1', week_a, hours_a, week_b, hours_b], "week_a LIKE '%Planned%'")
Then it must be the reference to week_a in your selection statement that's bombing it.  (I didn't notice that).
If you are using python 3.x I suggest using an f string like this:
(fc, ['OBJECTID_1', week_a, hours_a, week_b, hours_b], f'{week_a} LIKE "%Planned%"')
of if you are using python 2.x you'll need to use the format() method:
(fc, ['OBJECTID_1', week_a, hours_a, week_b, hours_b], '{} LIKE "%Planned%"'.format(week_a)
(Of course these are untested, but I think that'll get you going...)
