Create Vector Tile Package Different Results in ArcGIS Pro and Standalone Python Script
1871
8
02-20-2018 03:43 PM
GeoffreyWest
Occasional Contributor III
I have a script which creates a vector tile package.  I am receiving the error: ERROR 001856: Cached scale doesn't match tiling scheme only when I run the tool from a standalone Python script.  I use the same parameters in the GUI of ArcGIS Pro and the tool works fine.  Is this an ArcPy bug?  If I don't use a min and max scaling the tool runs successfully but takes forever due to the size of the dataset.
Here is my script:
from arcgis.gis import GIS
import os
import arcpy
#set environment settings
gis = GIS("myportal")
arcpy.env.overwriteOutput = True
outputPath = r"\\myOutPath\"
arcpy.env.parallelProcessingFactor = "66%"
# Loop through the project, find all the maps, and
#   create a vector tile package for each map,
#   using the same name as the map
p = arcpy.mp.ArcGISProject(r"\\CPVektrTile.aprx")
for m in p.listMaps():
    print("Indexing " + m.name)
    arcpy.CreateVectorTileIndex_management(m, outputPath + m.name + '.shp', "ONLINE", "", 10000)
    print("Packaging " + m.name)
    arcpy.management.CreateVectorTilePackage(m, outputPath + m.name + '.vtpk', "ONLINE", "", "INDEXED", 100000, 3000, r"\\CPAreas.shp")
print ("Adding VTPK to Test Portal")
vtpk_item = gis.content.add({}, data=outputPath + m.name + '.vtpk', folder='packages', overwrite=True)
print ("Publishing & Overwriting VTPK to Test Portal")
vtpk_layer = vtpk_item.publish(overwrite=True)
vtpk_layer.share(groups="SCG - Cathodic Protection")
Screenshot of successful run from geoprocessing tool in ArcGIS Pro:
Code sent to Python Window from history:
arcpy.management.CreateVectorTilePackage("CPAreas", r"C:\db\vtpktest_2.vtpk", "ONLINE", None, "INDEXED", 100000, 3000, r"\\\CPAreas.shp", None, None)
Tags (1)
by Anonymous User
Not applicable
Hey Geoffrey,
Were you ever able to figure this out? I am having this issue as well. I would like to be able to set the min and max scales in Arcpy due to the size of my dataset, but am seeing this same error. I have a large number of layers and would really like to script it. Thanks!
GeoffreyWest
Hi Ethan,
I don't remember what my solution was with this, a colleague has since
taken over the project. I will take a look at her code and get back to you.
by Anonymous User
Not applicable
Thanks, no worries if you cannot find it!
GeoffreyWest
Hi Ethan,
Here is the refactored code.  It looks like the script gets the map properties.  Hope it helps.
import os
import logging
import logging.handlers
import time
import configparser
import SendEmail
import arcpy
import sys
def getMapProperties(mapPropsList):
 mapProperties = {}
 for i in range(0, len(mapPropsList)):
 props = mapPropsList[i].split(",")
 mapname = props[0]
 mapnameupper = mapname.upper()
 mapProperties[mapnameupper]={}
 mapProperties[mapnameupper]['mapname'] = props[0]
 if len(props) > 1:
 mapProperties[mapnameupper]['minscale'] = props[1]
 else:
 mapProperties[mapnameupper]['minscale'] =""
 if len(props) > 2:
 mapProperties[mapnameupper]['maxscale'] = props[2]
 else:
 mapProperties[mapnameupper]['maxscale'] =""
 if len(props) > 3:
 mapProperties[mapnameupper]['vtpkindex'] = props[3]
 else:
 mapProperties[mapnameupper]['vtpkindex'] = ""
 return mapProperties
def createVtpk(m, mapProperties, indexGDBPath, vtpkPath, logger):
 mapName = m.name
minscale = ""
 maxscale =""
 vtpkindexfile = ""
 mapNameUpper = mapName.upper()
 if mapNameUpper in mapProperties:
 minscale = mapProperties[mapNameUpper]['minscale']
 if minscale !="":
 minscale = float(minscale)
 maxscale = mapProperties[mapNameUpper]['maxscale']
 if maxscale !="":
 maxscale = float(maxscale)
vtpkindex = mapProperties[mapNameUpper]['vtpkindex']
 if vtpkindex != "":
 vtpkindexfile = os.path.join(indexGDBPath, vtpkindex)
 logger.info("Creating Vector Tiles for " + mapName)
 arcpy.management.CreateVectorTilePackage(m, vtpkPath, "ONLINE", "", "INDEXED", minscale, maxscale, vtpkindexfile)
return vtpkPath
 return ""
def uploadVtpk(gis, vtpkName, vtpk, logger):
 vtpkFile = gis.content.search(query="title:"+vtpkName, item_type="Vector Tile Package")
 for i in range(0, len(vtpkFile)):
 item = vtpkFile[i]
 if item.title.upper() == vtpkName.upper():
 logger.info("Deleting Old VTPK Package From Portal")
 item.delete()
 break
 logger.info("Uploading VTPK package")
 vtpk_item = gis.content.add({}, data=vtpk)
if vtpk_item == None:
 logger.error("Error adding " + vtpk + " to Portal")
 return vtpk_item
def publishVtpk(gis, vtpkName, vtpk_item, portalGroups, logger):
 vtpkLayer = gis.content.search(query=vtpkName, item_type="Vector Tile Service")
 for i in range(0, len(vtpkLayer)):
 vLayer = vtpkLayer[i]
 if vLayer.title.upper() == vtpkName.upper():
 logger.info("Deleting Old VTPK Service From Portal")
 vLayer.delete()
 break
logger.info("Publishing VTPK service")
 vtpk_service = vtpk_item.publish()
 vtpk_item.delete()
logger.info("Sharing to Group in Portal")
 for group in portalGroups:
 cp_group = gis.groups.search('title:' + group, max_groups=15)
 for i in range(0, len(cp_group)):
 cpgroup_share = cp_group[i]
 if cpgroup_share.title.upper() == group.upper():
 vtpk_service.share(groups=cpgroup_share.id)
 break;
 return vtpk_service
def SendErrorNotification(emailTo, emailFrom, msg):
 for email in emailTo.split(";"):
 SendEmail.email_error_msg(emailTo, emailFrom, msg)
def main():
 if len(sys.argv) == 1:
 print("Please provide parameter for config file")
 sys.exit()
if not os.path.isfile(sys.argv[1]):
 print("Config file does not exist")
 sys.exit()
 cfile = configparser.ConfigParser()
 cfile.read(sys.argv[1])
 portalUrl = cfile.get('Portal', 'PortalUrl')
 portalGroupsList = cfile.get('Portal', 'PortalGroup')
 portalGroups = portalGroupsList.split(";")
 workspace = cfile.get('Folder', 'Workspace')
 outputPath = cfile.get('Folder', 'OutputFolder')
 logFile = cfile.get('Folder', 'LogFile')
 emailTo = cfile.get('Notification', 'EmailTo')
 emailFrom = cfile.get('Notification', 'EmailFrom')
 vtpkIndexFolder = cfile.get('VTPK', 'VtpkIndexFolder')
 project = cfile.get('VTPK', 'ProProject')
 mapProps = cfile.get('VTPK','MapProperties')
 mapProperties = getMapProperties(mapProps.split(';'))
logger = logging.getLogger('vectortiles_oca')
 logger.setLevel(logging.INFO)
 formatter = logging.Formatter('%(asctime)s - %(levelname)s - %(message)s')
 handler = logging.handlers.RotatingFileHandler(logFile, maxBytes=100000, backupCount=5)
 handler.setFormatter(formatter)
 logger.addHandler(handler)
gis = GIS(portalUrl, verify_cert=False)
 arcpy.env.workspace = workspace
logger.info("XXXXXXXXXXXXXXXXXXXXXXXX=Start")
 p = arcpy.mp.ArcGISProject(project)
 maps = p.listMaps("*")
 for i in range(0, len(maps)):
 try:
 if maps[i].name.upper() in mapProperties:
 vtpk = os.path.join(outputPath, maps[i].name + '.vtpk')
 if os.path.exists(vtpk):
 backupPath = os.path.join(outputPath, "backup")
 newname = os.path.join(backupPath, maps[i].name + '_'+ datetime.datetime.today().strftime('%Y%m%d%H%M') + '.vtpk')
 logger.info("Renaming existing VTPK to " + newname)
 os.rename(vtpk, newname)
 tryagain = True
 count = 0
 while tryagain:
 count = count + 1
 if count == 5:
 break
 try:
 vtpkPath = createVtpk(maps[i], mapProperties, vtpkIndexFolder, vtpk, logger)
 vtpk_item = uploadVtpk(gis, maps[i].name, vtpk, logger)
 publishVtpk(gis, maps[i].name, vtpk_item, portalGroups,logger)
 tryagain = False
 except Exception as e:
 logger.error(e, exc_info=True)
 if count ==3:
 SendErrorNotification(emailTo, emailFrom, "Encountered an error - " + maps[i].name + ". trying again." + str(e))
 SendErrorNotification(emailTo, emailFrom, "Vector Tiles Script has failed for map " + maps[i].name + ": " + str(e))
 del gis
 logger.info("XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=Complete")
if __name__ == '__main__':
 main()
by Anonymous User
Not applicable
That makes sense, and is a good idea. Thanks for this!
DanDeegan
New Contributor III
Thanks for following up with on your original comment. I am going to be attempting to do something similar and spent some time formatting the code as I tried to follow it.
Here it is. I think I got the indentations right...
if anyone notices errors let us know.
I assume there is a way to update the vtpk source in portal.
# -*- coding: utf-8 -*-
Created on Wed Jun 26 13:10:43 2019
******not my code*****
source https://community.esri.com/thread/210061-create-vector-tile-package-different-results-in-arcgis-pro-and-standalone-python-script
import os
import logging
import datetime  # used to be time
import configparser
import SendEmail
import arcpy
import sys
    mapProperties = {}
        mapname = props[0]
        mapProperties[mapnameupper] = {}
        if len(props) > 1:
        else:
            mapProperties[mapnameupper]['minscale'] = ""
        if len(props) > 2:
        else:
            mapProperties[mapnameupper]['maxscale'] = ""
        if len(props) > 3:
        else:
    mapName = m.name
    minscale = ""
    maxscale = ""
    vtpkindexfile = ""
    if minscale != "":
    if maxscale != "":
    if vtpkindex != "":
    return vtpkPath
    return ""
        item = vtpkFile[i]
            item.delete()
        break
        if vtpk_item is None:
    return vtpk_item
            vLayer.delete()
        break
        vtpk_item.delete()
        break  # used to be a ; here
    return vtpk_service
def main():
        sys.exit()
    sys.exit()
    mapProps = cfile.get('VTPK', 'MapProperties')
                                                   maxBytes=100000,
                                                   backupCount=5)
        try:
                newname = os.path.join(backupPath, maps[i].name + '_' +
                                       + '.vtpk')
                tryagain = True
                count = 0
            while tryagain:
                count = count + 1
                if count == 5:
                    break
                try:
                                          vtpk, logger)
                    publishVtpk(gis, maps[i].name, vtpk_item, portalGroups, logger)
                    tryagain = False
                    if count == 3:
                                              + maps[i].name
    del gis
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
TraceStanford1
New Contributor III
Did you get this script to work? I've tried, but keep getting the 'Please provide parameter for config file'  message. Where do you plug in your project?
DanDeegan
New Contributor III
We don't use vector tiles very often in web maps because they won't show up in legends. I do use vector tiles for contour lines and some other things with tons of geometry. Which don't need to be updated, so I don't need to automate it.
the config part is something I am trying to use now. You set parameters in a text file and get them out. So you need to create one. I am guess this one uses json.
