Create subfolder and FileGeodatabase?
4441
8
03-28-2022 07:28 AM
RPGIS
by MVP Regular Contributor
I have been trying to figure out why I keep running into this strange issue. I am not sure if I programmed the script incorrectly or if it happens to be an issue with establishing the subfolder first. Here is what I have so far.
import arcpy
import os
def CreateBaseData(location, names):
    subfolder_name = None
    database_name = None
    subfolder = None
    database = None
    for name in names:
        if '.gdb' in name:
            database_name = name
        else:
            subfolder_name = name
    for root, directory, filenames in os.walk(location):
        if directory:
            if directory[0] in names:
                if database_name == directory[0]:
                    database = os.path.join(root, directory[0])
                elif subfolder_name == directory[0]:
                    subfolder = os.path.join(root, directory[0])
                else:
                    pass
    if subfolder is None:
        subfolder = os.mkdir(os.path.join(location, subfolder_name))
    else:
        if database is None:
            database = arcpy.CreateFileGDB_management(subfolder, database_name)
    return database
# Create folder and file geodatabase
WorkingFolder = r'*'
subfolderName = 'Updates'
databaseName = 'Updates.gdb'
names = [subfolderName, databaseName]
database = CreateBaseData(WorkingFolder, names)
print (database)
Here is what I get as a print statement for the first, then second execution.First execution.png
Any help on this would be greatly appreciated.
GKmieliauskas
Try this below. I have changed WorkingFolder for testing.
import arcpy
import os
    subfolder = None
    database = None
    for name in names:
        if '.gdb' in name:
        else:
    subfolder = os.path.join(location, subfolder_name)
    database = os.path.join(subfolder, database_name)
    if (os.path.isdir(subfolder) == False):
        os.mkdir(subfolder)
    else:
        if (arcpy.Exists(database) == False):
    return database
WorkingFolder = os.path.dirname(__file__)
print(database)
GKmieliauskas
I think you need to delete line #28 and align next if to the first one
RPGIS
I tried that at first and it keeps returning an error.
RhettZufelt
MVP Notable Contributor
I can't get past line 16 as it doesn't seem like the * passed as a path in line 35.
The filename, directory name, or volume label syntax is incorrect: '*\\Updates'
Have you tried hard coding the WorkingFolder and see if you get past the error?
R_
RhettZufelt
Once I hardcode the working directory, it appears as if it is not getting past this part:
        if directory:
                else:
                    pass
Since the "Updates" folder doesn't exist yet, nothing past the if directory[0] in names: resolves to true.
So when it hits this part:
    else:
the subfolder doesn't exist, so it creates it.  BUT, it doesn't execute the else: as the first part was true.
Then next time you run it, subfolder now exists, so is not None, so it executes the else: statement and creates the FGDB.
Think you need to deal with checking/creating the working folder before you walk through it. Or, just have it check if subfolder exists and database doesn't, create it.
R_
RPGIS
Would it be recommended to have to loop through again to look for the database or have it simply check to see if either folder exists? I thought about using os.path.exists to determine the existence of both the database and folder. Depending on which exists; create either one or the other.
GKmieliauskas
import arcpy
import os
    subfolder = None
    database = None
    for name in names:
        if '.gdb' in name:
        else:
        os.mkdir(subfolder)
    else:
    return database
print(database)
RPGIS
Thank you very much @GKmieliauskas ,
That seems to do the trick. I don't know why I couldn't figure out the little tidbit that kept holding me up. I am trying to simplify my scripts, using functions, to reduce the amount of code I have to write.
Also, I am trying to keep this section of code constant with all my scripts to eliminate the process of recreating baseline data. I don't know if it makes sense to do this or not but just thought to ask.
GKmieliauskas
Less code is right way. It is better to use arcpy functionality to check database existing or where available. Make python modules to store reusable code.
