So I am kind of new to python world and I'm trying to create a polygon feature class including multiple polygons from a csv file attached (parcel_points.csv) containing 3 columns: "PARCELID", "POINT_X", "POINT_Y".
I followed the code sample from https://pro.arcgis.com/en/pro-app/latest/arcpy/get-started/writing-geometries.htm. I'm currently stuck on separating each polygon by "PARCELID" but I keep getting "RuntimeError: Object: CreateObject cannot create geometry from inputs". Where did I do wrong?
import os
import arcpy
import fileinput
in_dir = "D:/WPS/JHU/Programming in GIS AS.430.606.81.SP22/Week 13/Final"
csvFile = "parcel_points.csv"
fc = "polygonFromCSV"
geoType = "Polygon"
in_csv = os.path.join(in_dir, csvFile)
arcpy.env.workspace = in_dir
sr = arcpy.SpatialReference(26910)
arcpy.management.CreateFeatureclass(in_dir, fc, geoType, "", "", "", sr)
with arcpy.da.InsertCursor(fc, ["SHAPE@"]) as cursor:
array = arcpy.Array()
point = arcpy.Point()
tempID = -1
for line in fileinput.input(in_csv):
if not fileinput.isfirstline():
point.ID, point.X, point.Y = line.split(",")
if tempID == -1:
tempID = line[0]
if tempID != line[0]:
cursor.insertRow([arcpy.Polygon(array)])
array.removeAll()
point.removeAll()
array.add(point)
tempID = line[0]
fileinput.close()
Solved! Go to Solution.
To fix your problem you will need to alter your code to:
The code will look like this:
import csv
import os
import arcpy
in_dir = "D:/demo"
# Create output feature class
in_dir, fc, geometry_type="POLYGON", spatial_reference=sr
out_feature_class = os.path.join(in_dir, fc)
# Add a field to transfer PARCELID from input csv
arcpy.management.AddField(out_feature_class, "PARCELID", "LONG")
with arcpy.da.InsertCursor(out_feature_class, ["SHAPE@", "PARCELID"]) as cursor:
point_list = []
parcel_value = None
is_first_pass = True
with open(in_csv, mode="r") as csv_file:
csv_reader = csv.reader(csv_file, delimiter=",")
header = next(csv_reader)
for row in csv_reader:
#print(f"Parcel id:{row[0]} with X {row[1]} and Y {row[2]}.")
if is_first_pass:
parcel_value = row[0]
is_first_pass = False
elif row[0] != parcel_value:
# Parcel ID has changed, write the polygon
polygon = arcpy.Polygon(arcpy.Array(point_list), sr)
cursor.insertRow([polygon, parcel_value])
# Reset the current group
point_list = []
# Add the point to the feature's array of points
point_list.append(arcpy.Point(row[1], row[2]))
# final insert
import numpy as np
import arcpy
name = "c:/temp/parcel_points.csv"
dt = np.dtype([('PARCELID', 'i8'), ('POINT_X', 'f8'), ('POINT_Y', 'f8')])
a = np.genfromtxt(
name, dtype=dt, delimiter=",", names=True, autostrip=True,
encoding=None)
ids = a['PARCELID']
w = np.nonzero((ids[1:] - ids[:-1] != 0))[0]
p_lst = np.array_split(a, w)
frst = p_lst[0]
xs = frst[['POINT_X', 'POINT_Y']].tolist()
p = arcpy.Polygon(arcpy.Array([arcpy.Point(i[0], i[1]) for i in xs]))'p' is the first polygon (line 11 and 12) in the 'p_list' which was obtained from splitting the array based on where the PARCELID s breakpoints occurred.
You can cobble the rest of the polygons by creating a list to hold the polygons and cycle through lines 11 to 13.
Thank you so much for the help! I forgot to mention that the task has to be completed via insertcursor method. I believe I'm almost there since I was able to create an unseparated polygon through the code below. I'm just not able to separate them through ID.
import os
import arcpy
import fileinput
in_dir = "D:/demo"
geoType = "Polygon"
array.add(point)
fileinput.close()
Has to be done by an insertcursor?
cobble the parts from above that does the splitting, then throw it into your cursor if you must
I have updated the code above and solved the runtime error. It was caused by false indentation. But the code still not able to separate polygons by ID. Is there anyway this code can be improved instead of rewriting the whole thing to make it work?
import csv
import os
import arcpy
in_dir = "D:/demo"
point_list = []
parcel_value = None
if is_first_pass:
point_list = []
# final insert
