Create a raster grid in vertical plane from xyz data
1350
07-17-2013 07:24 AM
ShaneCarey
Hi
I need to create a grid of the point dataset (image attached) and export as a .grd file so that it can imported into ArcScene. I am using python xy and mayavi library to visualise this data.
If anyone could help me with this problem, I would greatly appreciate it.
Thanks in advance
[ATTACH=CONFIG]26009[/ATTACH]
JakeSkinner
Esri Esteemed Contributor
Hi Shane,
You can use the IDW tool to interpolate a raster surface from points.  The resulting raster can then be used in ArcScene.
ShaneCarey
Hey,
For some reason, idw will not work. I think this is because I'm working in a vertical plane as opposed to a horizontal plane. Is there a way to possibly flip the data by 90 degres so that it is on a horizontal plane, create the grid and reflip back perhaps?
