# Specifying the environment settings arcpy.env.workspace = outWorkspace arcpy.env.tileSize = "512 512" arcpy.env.compression = "JPEG2000 75" arcpy.env.pyramid = "NONE" #Copying the raster arcpy.CopyRaster_management(filepath,name + ".jp2","DEFAULTS","0","0","","ColormapToRGB","8_BIT_UNSIGNED")
Same here -- my script has
arcpy.env.compression = "JPEG2000"
but I end up with LZ77 anyway, which results in a dataset that is too huge. If I can't script this then I have to run it by hand to get the result I need.
Paul
Paul Cone
Corporate GIS
City of Portland, Bureau of Technology Services
Is this still an issue in ArcMap 10.4.1?
