Copy attributes from layer to table except OID and Geometry
827
08-27-2019 09:03 AM
CCWeedcontrol
Occasional Contributor III
I am trying to copy attributes from a layer to a table but the Geometry fields are giving me problems. I need help ignoring the OID and Geometry fields and i though line 11 would do it.
The feature class fields
Shape.STArea() & Shape>STLength()
Table fields
Shape_STarea_ & Shape_STLength
I have the following but get error.
line 17, in <module>
    iCur.insertRow(row)
RuntimeError: Cannot find field 'Shape.STArea()'
arcpy.env.workspace = r"C:Temp\Test.gdb"
database = r"C:Temp\Test.gdb"
fc1 = "TestLayer1
fc2 = "Table1"
dsc = arcpy.Describe(fc1)
fields = dsc.fields
# List all field names except the OID field and geometry fields
fieldnames = [fields.name for fields in fields if fields.name != dsc.OIDFieldName and fields.type != 'Geometry']
# Create cursors and insert new rows
with arcpy.da.SearchCursor(fc1,fieldnames) as sCur:
    with arcpy.da.InsertCursor(fc2,fieldnames) as iCur:
        for row in sCur:
            iCur.insertRow(row)
del sCur
JoshuaBixby
MVP Esteemed Contributor
Have you tried GDB FeatureClass properties—ArcPy Functions | ArcGIS Desktop
Properties
PropertyExplanationData Type
areaFieldName
(Read Only)
The name of the geometry area field.
String
lengthFieldName
(Read Only)
The name of the geometry length field.
String
DanPatterson_Retired
use the new data access Describe instead of the old.  access is via a dictionary key value
desc = arcpy.da.Describe(in_fc)
flds = arcpy.ListFields(in_fc)
[fld.name for fld in flds if fld.name != desc['OIDFieldName'] and fld.type != 'Geometry']
['Parts',
 'Points',
 'Curves',
 'Shape_Length',
 'Shape_Area',
 'A0',
 'A1',
 'Value_0']
CCWeedcontrol
I got a typeError
fldnames = [fld.name for fld in flds if fld.name != desc['OIDFieldName'] and fld.type != 'Geometry']
TypeError: 'geoprocessing describe data object' object is not subscriptable
JoshuaBixby
Properties
areaFieldName
(Read Only)
String
lengthFieldName
(Read Only)
String
CCWeedcontrol
Yes that did it and 'Shape.STArea()' and fields.name != 'Shape.STLength()' would have probably worked too.
fields.name for fields in fields if fields.name != desc.OIDFieldName and fields.type != 'Geometry' and fields.name != desc.areaFieldName and \
            flds.name != desc.lengthFieldName]‍‍‍‍
