Coordinates Conversion Based on Criteria Using Python
818
10-15-2020 03:45 PM
CrossrailGIS
New Contributor III
I am trying to develop a custom tool to be used as a widget in Web AppBuilder. The tool should be able to return x, y coordinate values using default projection system (e.g. London Survey Grid) based on user’s click on the map. Then the returned x, y coordinate values should generate another set of x, y coordinate of the same location using some criteria (If and else statement).
The scenario is as below:
1. User clicks on the map and returns X, Y value (default projection system)
Let’s say X = 45670 and Y = 55000
2. Re-project or convert the returned X and Y values from step 1 to another set of coordinates of the same location (P2_X, P2_Y2)  using criteria below:
Criteria is: (This is just a sample, but I have a long real criteria)
If X == 0 and Y == 0:
   return Projection2 (0,0)
elif X >= 44274 and X <= 45799 and Y >= 53927 and Y <= 54889:
   P2_X = (X * 0.999942) – (Y * 0.2519)
   P2_Y = (Y * 0.999942) + (X * 0.2519)
   return Projection2(P2_X , P2_Y)
else:
    P2_X = (X * 0.98888) – (Y * 0.4519)
    P2_Y = (Y * 0.98888) + (X * 0.4519)
3. Then display both X, Y and P2_X, P2_Y
I have my python script that returns X,Y based on the user’s click on the map, but I am struggling in returning P2_X and P2_Y based on the criteria as mentioned above. I have a separate python script for the criteria. Please let me know if any one can help me on this, I can share my script if needed.
Thanks for your help in advance.
-Sushil
DanPatterson
MVP Esteemed Contributor
if (X==0) and (Y==0):
elif (X >= 44274 and X <= 45799) and (Y >= 53927 and Y <= 54889):
Assuming your sample was supposed to be in python code, the above lines would have benefited from a proper equality check ( == ), the use of brackets to ensure or clarify proper expression parsing and colon was missing
If your sample was a generic expression, did you get error messages? or improper values? since I am not sure what the "code" represents
... sort of retired...
CrossrailGIS
New Contributor III
Hi Thanks, for that. This was just the typo here but i do have == and : in my script properly coded. The main challenge here is how to relate and define X and Y coordinate value is equal to coordinate values returned from user's clicked point. That means the returned coordinate value should be equal to X, Y value in the script above. I am using  arcpy.da.SearchCursor(feature_record_set_layer, ['SHAPE@']) as cursor: for clicking and returning coordinate values.
-Sushil
DanPatterson
Still not sure how the script fits in, but SHAPE@ is going to return a list of 4 values, if it is a point (the last two values are for potential Z and M values.
You might want to use [SHAPE@X, SHAPE@Y], hence, conceptually
X, Y = [SHAPE@X, SHAPE@Y]
I can only assume you are already getting the point from the click (or are you?)
CrossrailGIS
New Contributor III
Hi Dan,
Thanks. I can share my full script to you if i have your email if that's ok? I thought it might be easier in that way!
Thanks
DanPatterson
You can project to a different coordinate system within the search cursor
fc2 = r"C:\Git_Dan\npgeom\Project_npg\tests.gdb\sq" # ---- a sample featureclass
import arcpy
SR0 = arcpy.da.Describe(fc2)['spatialReference']
SR1 = arcpy.SpatialReference(4326)
# ---- in its native projected coordinate system
with arcpy.da.SearchCursor(fc2, ['SHAPE@X', 'SHAPE@Y'], spatial_reference=SR0, explode_to_points=True) as cur:
    a = cur._as_narray()
# ---- projected to a GCS
with arcpy.da.SearchCursor(fc2, ['SHAPE@X', 'SHAPE@Y'], spatial_reference=SR1, explode_to_points=True) as cur:
    b = cur._as_narray()
a
array([( 300009.00,  5000001.00), ( 300000.00,  5000000.00), ( 300002.00,  5000008.00), ( 300008.00,  5000010.00),
       ( 300010.00,  5000010.00), ( 300010.00,  5000008.00), ( 300009.00,  5000001.00), ( 300003.00,  5000003.00),
       ( 300007.00,  5000003.00), ( 300005.00,  5000007.00), ( 300003.00,  5000003.00), ( 300010.00,  5000008.00),
       ( 300010.00,  5000010.00), ( 300008.00,  5000010.00), ( 300008.00,  5000011.00), ( 300008.00,  5000012.00),
       ( 300012.00,  5000012.00), ( 300012.00,  5000008.00), ( 300010.00,  5000008.00), ( 300008.00,  5000011.00),
       ( 300005.00,  5000010.00), ( 300005.00,  5000012.00), ( 300006.00,  5000012.00), ( 300008.00,  5000012.00),
       ( 300008.00,  5000011.00), ( 300006.00,  5000012.00), ( 300005.00,  5000012.00), ( 300005.00,  5000015.00),
       ( 300007.00,  5000014.00), ( 300006.00,  5000012.00)], dtype=[('SHAPE@X', '<f8'), ('SHAPE@Y', '<f8')])
b
array([(-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14),
       (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14), (-76.56,  45.14)],
