Convert VB to Python, Help?
9316
14
08-03-2017 05:06 PM
TomMagdaleno
Hi all, I am new to Python and trying to make an older piece of code work.  It takes two tables, compares them, and if data in table A doesn't match table B it overwrites A with B.
If they are equal it leaves them alone...
dim intval
if [STR_NUM] = [SITUS_NR] then
intval = " "
else
intval = [STR_NUM]
end if
If it finds a "nil" in a field in table B it clears the field in table A
dim intval
if [STR_NUM] = "nil" then
intval = " "
else
intval = [SITUS_NR]
end if
Finally it overwrites table A if it finds data in table B
dim intval
if [STR_NUM] <> " " and [STR_NUM] <> "nil" then
intval = [STR_NUM]
else
intval = [SITUS_NR]
end if
Can anyone help me convert these or at least one to Python?
Thank you!
RandyBurton
Per Dan's suggestion, paste the following code into the codeblock (top) section.
def func_shun(a, b):
    the_result = [a, ""][a == b]
    return the_result
In the lower section, paste only the following (I think I have the spelling of your joined tables correct):
func_shun( !asrerror_log_20170803.STR_NUM!, !cam_apn_old.SITUS_NR!)
VB would use square brackets around the field names, but Python uses exclamation marks.  So field calculator is getting confused.  You do have the Python parser selected.  The photo in my post below should help.
DanPatterson_Retired
Not applicable for file comparisons but could be implemented as a one-liner (line 11) or turned into a function (using lines 15-) for use within a program or the field calculator
intval = " "
else
intval = [STR_NUM]
end if
# ---- as a field calculator expression or a line of code ----
# for example a = 1, b = 2 or a = 'a', b = 'b'
[" ", a][a == b]  # [False, True][condition check]
# ---- more verbose
if a == b:
    val = " "
else:
    val = a
return val
# ---- more variations exist ----
TomMagdaleno
Ok, I'll try that out Dan.  It is a model builder that uses the field calculator.  I should have clarified that.  I converted this to modelbuilder a few years ago from Avenue, but Avenue still works and VB stopped working.  Go Figure.  With windows 10 probably neither will work so it needs to be in Python now.
avenue to python is a far easier transition syntactically ... have fun
RebeccaStrauch__GISP
Just for the off-chance that it is VBA and not VB, and if you are using 10.5.x...
At the ArcGIS Desktop 10.5 release, Microsoft Visual Basic for Applications (VBA) Compatibility is no longer included. The VBA Compatibility setup in prior versions can still be installed, but its usage is not supported and may result in software errors or crashes. It is recommended that existing Microsoft VBA users continue to use ArcGIS Desktop version 10.2.2 or earlier, or migrate VBA customizations to ArcMap add-ins, ArcPy scripts, or ArcGIS Pro add-ins built with the Pro SDK for .NET
ArcGIS Desktop 10.5.x system requirements—ArcGIS Help | ArcGIS Desktop
TomMagdaleno
So this is what I enter in the Field Calculator and I get a syntax error.  I thought maybe it was the colon in the first line but it makes no difference.  Can you spot the error?
if  !STR_NUM! ==  !SITUS_NR!:
    val = " "
else:
    val =  !STR_NUM!
return val
ClintonDow1
Assuming the tables are small enough to be held in memory, you can use set comparisons:
paths = {'table1': r'path\t1', 'table2': r'path\t2'}
sets = map(lambda t: {row for row in arcpy.da.SearchCursor(t, arcpy.ListFields(t))}, paths.values()]
if len(sets[0] - sets[1]) > 0:
   arcpy.management.DeleteRows(paths['table1'])
   arcpy.management.Append(paths['table2'], paths['table1'])‍‍‍‍‍
edit: This compares the entire tables, not row-by-row, I might have misunderstood what you wanted..
    """to use... this function goes in the code block
    :  func_shun(!first_field!, !second_field!) ... goes in the expression box
    """    the_result = [a, ""][a == b]  # this is conceptual, replace a and b
    return the_result‍‍‍‍‍‍
your whole code block needs to go in a 'def' and indented 4 lines.
There is a 'code' block, which is where the 'def' goes, then there is an expression box, where the call to the function is made.  In the above example... you would put
func_shun(!STR_NUM!, !SITUS_NR!)
same line if you fix up your other code block
TomMagdaleno
Sorry Dan,
  I think I get what we are trying to do, but I don't know why it isn't working.  See the error below.  This is with joined tables so the A and B names are a lot longer.
error
RandyBurton
    return the_result
