code for checking whether data driven pages enabled
605
04-01-2011 08:48 AM
ErinIverson
Is there a means of checking, in Python, whether data driven pages are enabled in a particular MXD?
All the code and help I can find seems to imply this verification must take place manually, and if I call
mxd.dataDrivenPages
for a map document object that doesn't have DDP, I get an error.
  File "<interactive input>", line 1, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 447, in dataDrivenPages
    return convertArcObjectToPythonObject(self._arc_object.pageLayout.dataDrivenPages)
AttributeError: PageLayoutObject: Get attribute dataDrivenPages does not exist
StevenArebalo
Maybe creating a try that catches the specific AttributeError and informs the user? It really isn't checking for DDP enabled, but will provide the same end result.
JasonScheirer
Use either
if mxd.supports("dataDrivenPages"):
or
if hasattr(mxd, "dataDrivenPages"):
JonPedder
Is it still the case that there isn't a way to turn DDP on/off within Python?
AdhimoolamD
Hi
yes, the below code is working fine to check whether the DDP enabled in the MXD.
But the DDP can be enabled with only one Map Dataframe. in otherway, if the MXD have more than one Dataframe, then let me know the DDP enabled to which dataframe.
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Projects\Untitled_new.mxd")
    print "yes"
else :
    print "No"
