Change field length using arcpy.FeatureClassToFeatureClass_conversion
7031
9
05-14-2015 11:20 AM
MichaelCarson4
New Contributor III
My goal is to take a shapefile, change the length of one of the text fields, and save a new shapefile using arcpy.FeatureClassToFeatureClass_conversion.  You can do it using the tool's interface, just add a shapefile to it and the fields are listed, right click on a field to change it's properties and change the field length, then save to a new shapefile.
But how to do that using code?  I think you have to manipulate the field mapping to do it, but I cannot seem to find where you make the change for a particular field.  So far I have:
>>> inshp = "c:/temp/test1.shp"
>>> fms = arcpy.FieldMappings()
>>> fms.addTable(inshp)
>>> fms.fieldCount
6
>>> fm = fms.getFieldMap(0)
>>> fm.getInputFieldName(0)
u'CITY_NAME'
So how do I change the field length for the CITY_NAME field and save it back to the field mapping?  Once that is done, I guess you put the field mapping back into the tool:
arcpy.FeatureClassToFeatureClass_conversion(inshp, "c:/temp", "test2.shp", "", field_mapping=fms)
DarrenWiens2
MVP Honored Contributor
The following changes the length of the field.
>>> inshp = "line"
... fms = arcpy.FieldMappings()
... fm = arcpy.FieldMap()
... fm.addInputField(inshp,"myField")
... newField = fm.outputField
... newField.length = 100
... fm.outputField = newField
... fms.addFieldMap(fm)
... arcpy.FeatureClassToFeatureClass_conversion(inshp, r'C:/junk', 'newshp', field_mapping=fms)
Note that you must make your changes in a new field object ("newField") rather than fm.outputField. I won't say I understand why this is, it just is. For example, this will not change the output field length, although I would have guessed, like you, that it should:
>>> inshp = "line"
... fm.outputField.length = 100
... arcpy.FeatureClassToFeatureClass_conversion(inshp, r'C:/junk', 'newshp2', field_mapping=fms)
IanMurray
Why not take the output of your manual FC to FC conversion and copy it as a python snippet and see what is going on(Go to Geoprocessing Results, navigate to the process, right click and select copy as python snippet)?  From there it should be fairly easy to determine what changes you want to make and how to manipulate fields.
MichaelCarson4
New Contributor III
I have, but it does not tell me what code to use to make it that way! -mike
DanPatterson_Retired
hmmm .... maybe a combination of
Add Field   ...
Calculate field ...
Delete Field ...
and/or ...
Transpose Fields    ...
will get you where you want since
Alter Fields  only allows you to change the field name
MichaelCarson4
New Contributor III
Wow, that's a lot of tools to use!  I'm getting closer in my code, but cannot change the field length so far:
>>> fm.outputField.name
u'CITY_NAME'
25
25
a couple of lines of code... to get you started
env.workspace = "C:/somefolder/a.gdb"
arcpy.AddField_management("some_layer", "cool_name", "DOUBLE", 12,6)   # double field 12 wide 6 decimals
arcpy.CalculateField_management("some_layer", "cool_name", "!old_field!", "PYTHON_9.3")
Etc
DarrenWiens2
>>> inshp = "line"
>>> inshp = "line"
MichaelCarson4
New Contributor III
Thanks Darren!  That does the trick and results in a shapefile with the one changed field.  If I want to bring over the others as is, I would loop through each to create a field map and then add them to the field mappings variable.  Then I would have a shapefile with all the fields and the one I changed too.
BlakeTerhune
MVP Regular Contributor
MichaelCarson4
New Contributor III
Done!
