I am attempting to use the Python API (not arcpy) in a Jupyter Notebook to load a feature class from SDE into a SpatialDataFrame.
# Snippet begins after standard boilerplate code for setting up a notebook
# for use with ArcGIS API for Python
from arcgis.features import SpatialDataFrame
sdf = SpatialDataFrame.from_featureclass(<path to feature class>)
I've successfully loaded several feature classes of varying geometry types into a SpatialDataFrame from the same SDE database without issue. However, I do have one feature class, RALEIGH.PARKS, that, when I try to load it, produces the following error:
Has anyone else run into problems loading a Feature Class from SDE into a SpatialDataFrame using the Python API? I'm personally not quite sure what further to troubleshoot this error and finding the docs to be a little spotty. Any suggestions on what I might try?
