Can f-strings be used in script tools?
1866
9
07-26-2021 01:37 PM
ChrisGAEG
Can script tools use f-strings? I'm getting an 'ERROR 000354: The name contains invalid characters'.  The line that is causing the error is as follows -
arcpy.FeatureClassToFeatureClass_conversion('Proposed_OLT_LCP_Boundaries', scratch, f'{lcpNameFixed}_Boundary', exp)
 Here is how lcpNameFixed is assigned.
lcps = arcpy.GetParameterAsText(0)
lcpNameFixed = lcp.replace('-', '')
 The value list of lcps has dashes ('-') but the lcpNameFixed takes the dashes out. The lcps value list doesn't start with numbers either.  I just want to rule out if the f-string might be causing this invalid name error.
emedina
New Contributor III
I'd say your answer is "Yes" provided you're using the script tools with environments at version 3.6+ of Python. If you're reasonably sure no one's using a version older than that then your tools should be fine. However, if you want to ensure compatibility with older versions then you're stuck with .format, I guess.
emedina
New Contributor III
ChrisGAEG
Correct, I found that one of my layers had a '/' in the name. 😅  F-strings can be used in line as arguments. Thanks for the response.
Cristian_Galindo
Occasional Contributor III
Do you mean Pyhton 3.6+?
I can say for experience that some of the arcpy tools in Python 3.7 (ArcGIS Pro 2.9) that some of the tools accept f-string as parameters other does not:
This example does not work (using the f-string in the where_clause parameter):
where_clause_with_date_filter = f"{where_clause} AND {date_filter}"
points_select = arcpy.analysis.Select("{0}.{1}".format(schema_owner, TABLE_CAL_POINTS), r"memory\f{0}".format(uuid4().hex),where_clause_with_date_filter)
generates the error:
  File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\analysis.py", line 138, in Select
    raise e
  File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\analysis.py", line 135, in Select
    retval = convertArcObjectToPythonObject(gp.Select_analysis(*gp_fixargs((in_features, out_feature_class, where_clause), True)))
  File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 000358: Invalid expression f"{where_clause} AND {date_filter}"
Failed to execute (Select).
i have tried to use the f-string in search cursor, and update cursor and found that in the feature_class parameter,m it does not accept f-strings, but in the where_clause it does:
with arcpy.da.UpdateCursor("{0}.{1}".format(schema_owner, TABLE_LINKAGES),
                                   ["REFERENCE_FEATURE_ID"],
                                   where_clause=f"PROJECT_ID = '{project_id}'") as cursor:
DanPatterson
MVP Esteemed Contributor
f"{}"  == "{}".format()
However, the f-strings have almost implemented all the capabilities of the .format version.
For the casual/infrequent user, it is sometimes a preference between pre-fix versus post-fix notation.
For others it is the onerous task of typing the extra "ormat".
In any event, all variables/strings passed to either case needs to be raw-encoded at source prior to formatting to avoid nasty unexpected errors.
Try this on.
b ="{}".format(r"Ooops\a\b\t")
b
'Ooops\\a\\b\\t'
# ---- or
a = r"Ooops\a\b\t"
f"{a}"
'Ooops\\a\\b\\t'
# ----- now, omit raw encoding
c ="{}".format("Ooops\a\b\t")
c
'Ooops\x07\x08\t'
# --- etcetera
... sort of retired...
ChrisGAEG
Onerous indeed. Thanks again for the clarification Dan!
MattHowe
They can in main scripts but I've noticed validation scripts don't like them.
RyanDavis1
I'll add that I've noticed the consolidation and packaging tools tend to convert f-strings to .format and then assign them to g_ESRI_variables.  No idea why.
Generally speaking, I have little problem with f-strings but every so often Pro [2.6] returns an error.  Sometimes it's solved by simply closing the program and re-opening.  It seems really inconsistent.
DanPatterson
f strings are largely shortcuts to "".format .  there is no "real" advantage to using them and the capabilities of "format" haven't been completely replicated in f-strings.  Some people claim they are shorter but in reality most cases are only shorter by "ormat" characters 😉
MattHowe
Totally agree. I find using them to create definition queries in scripts easier but more than anything I think they make code a bit easier to read for people new to Python.
