arcpy.SignInToPortal "Failed to sign out" error
5104
02-04-2021 12:52 PM
azlotin
I am trying to create a map service definition file in Python (see a snippet below). The code fails on the line arcpy.SignInToPortal:
arcpy.SignInToPortal("****", "****", "****")
File "D:\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 2468, in SignInToPortal
return _SignInToPortal(*args, **kwargs)
ValueError: Failed to sign out.
I confirmed that I am not logged in to the portal on the machine which the script is executed. The portal URL and the user credentials are correct as well. Why am I getting the error and how to get around it? Thanks!
arcpy.SignInToPortal(portalURL, "MyUserName""MyPassword")
    sharingDraft = mp.getWebLayerSharingDraft("HOSTING_SERVER""FEATURE", serviceName)
    sharingDraft.portalURL = portalURL
    sharingDraft.portalFolder = serviceFolderName
    sharingDraft.description = newDescription
    sharingDraft.summary = "[Summary]"
    sharingDraft.tags = "[Tags]"
    sharingDraft.credits = "[Credits]"
    sharingDraft.useLimitations = "[Limitations]"
    sharingDraft.copyDataToServer = False
    sharingDraft.exportToSDDraft(sdDraftFilePath)
    arcpy.StageService_server(sdDraftFilePath, sdOutputFilePath)
by Anonymous User
Not applicable
Hi @azlotin,
My first guess would be the Portal URL.
I know that you have checked that it is correct, but do you have the real string identifier in front of the string?
e.g: r"https://<portal webadaptor url>/<webadaptor name>/"
If you have, then I would be looking to see if the script can ping the server first as t may be a network issue as well.
Michael
tigerwoulds
Did you ever get this resolved? I'm running into a similar issue.
CarstenB_orsted
I think Michael is spot on with the portal URL.
I ran into the same problem today, and found out that the portal URL read from a configuration file was something like this:
https://myserver/portal/home
When I changed to
everything worked!
JaredPilbeam2
I second @CarstenB_orsted .
This worked for signing in to AGOL:
# Sign in to AGOL
arcpy.SignInToPortal("https://wcountygis.maps.arcgis.com/", "user", "pass")
arcpy.SignInToPortal(r"https://wcountygis.maps.arcgis.com/", "user", "pass")
This didn't work:
arcpy.SignInToPortal("https://wcountygis.maps.arcgis.com/home", "user", "pass")
arcpy.SignInToPortal(r"https://wcountygis.maps.arcgis.com/home", "user", "pass")
Jay_Gregory
For us - this seems to be related to a self signed cert error.  If using the Python API, GIS('myportalurl', username, password) fails with ssl validation error unless I add verify_cert=False as a parameter.  The problem is, there is no way to do this using Arcpy.SignInToPortal, which is required for programmatically publishing services.
