arcpy Pro notebook old arcpy.SetProduct("arcinfo") <-> arcpy.CheckProduct("ArcInfo") question?
1497
02-14-2022 10:41 PM
JohannesBierer
we have a concurrent license model on a seperate server. We are only allowed to check out the advanced license for the needed time ... . In arcpy ArcMap you could set the product temporarily very easy, in Pro 2.8 notebook this doesn't seem to work with check product in our case.
There's always the message "ArcGIS for Desktop Advanced license not available" even if more than one  license is available with the following code?
import sys
import arcpy
arcpy.env.workspace = "c:/data/world.gdb"
if arcpy.CheckProduct("ArcInfo") == "Available":
    arcpy.PolygonToLine_management("Lakes", "LakeLines")
else:
    msg = 'ArcGIS for Desktop Advanced license not available'
    print(msg)
    sys.exit(msg)
Does this work only with licenses saved online?
Are there any workarounds?
It would be very uncomfortable to check out the license manually in Pro every time the advanced license is needed ...
DanPatterson
MVP Esteemed Contributor
And the Note in the followup link
Accessing licenses and extensions in Python—ArcGIS Pro | Documentation
sends you off to CheckInExtension etc. because CheckProduct has no effect in some situations.
(why everyone is licensed for everything is beyond me... it would make things so much easier... 😉  )
... sort of retired...
DanPatterson
