ArcPy - How do I run custom script tools within the console?
3673
6
01-12-2018 07:53 AM
MarcusSanders2
New Contributor II
For example, I have a custom tool "wellTabletoFC". When I pull up the Item Description, it gives me a syntax as if it can be used within the console:
wellTabletoFC(Input_Table)
When I drag the script into the Python window, I get this code:
>>> arcpy.wellTabletoFC()
Runtime error
  File "<string>", line 1, in <module>
AttributeError: 'module' object has no attribute 'wellTabletoFC'‍‍‍‍‍
How do I use my own tools in the same way as ArcGIS tools within ArcPy, for example:
arcpy.Project_management(
    in_dataset,
    out_dataset,
    out_coor_system,
    transform_method,
    {in_coor_system},
    {preserve_shape},
    {max_deviation},
    {vertical}
I want to do this for 2 reasons:
  1. Run the tool within the Python console, while being able to return the tool output into a variable,
  2. Chain multiple custom tools together that are maintained separately, into a single workflow
Tags (3)
JonathanQuinn
Esri Notable Contributor
If it's a script tool in a toolbox, you can import the toolbox and script tool:
Adding toolboxes in Python—Geoprocessing and Python | ArcGIS Desktop
DanPatterson_Retired
is it a script? (aka module) in a location that is within your import path?
import wellTabletoFC
JonathanQuinn
MarcusSanders2
New Contributor II
Just what I was looking for, works perfectly! Thank you
MarcusSanders2
New Contributor II
This doesn't seem to persist after ArcMap is closed; is this something that only works during that session?
JonathanQuinn
Yes, every time you run your script you need to import the toolbox, much like you need to import any modules at runtime as well.
MarcusSanders2
New Contributor II
That makes sense, thank you
