arcpy.GetMessages() in Python Toolbox does not return tool executed
4547
01-10-2019 01:03 PM
MalloryGill
I'm working on a Python toolbox and the function to get the geoprocessing messages doesn't seem to work as documented. I'm just using the arcpy.GetMessages() function
arcpy.AddMessage(arcpy.GetMessages())
and the result is
Start Time: Thursday, January 10, 2019 3:21:16 PM
Succeeded at Thursday, January 10, 2019 3:21:29 PM (Elapsed Time: 12.40 seconds)‍‍
If I use the arcpy.GetMessageCount() function, it likewise returns 2 as the result. This page of message documentation says that when using the GetMessages function "the first message gives the tool executed, and the last message gives the ending and elapsed time for the tool's execution. The tool's second and last messages always give the start and end time, respectively, for the tool's execution."
The part that I need, the name of the tool executed, isn't coming through. Even if I use the GetMessage function and specify the 0 index position, it still returns the start time. What am I missing?
DanPatterson_Retired
I prefer to add my own messages for documentation, that way you can use the basic python print function or see messages in the tool output section.  I suspect things that work and don't report messages aren't added
I add the running tool's name in the script and print or report to tool output
import sys
def tweet(msg):
    """Print a message for both arcpy and python.
    msg - a text message
    m = "\n{}\n".format(msg)
    arcpy.AddMessage(m)
    print(m)
script = sys.argv[0]
tweet("running {} script".format(script))
# ---- prints in python console and shows in the tool report section
# running C:/GIS/somescript.py script
You can always accumulate messages and 'tweet' at the end
msgs = ""
msgs += "hello"
msgs += " there "
tweet(msgs)
hello there
RandyBurton
Can you supply the code you are having issues with?  I haven't been able to duplicate your results.  In the meantime, here is an example of a python toolbox that utilizes arcpy.GetMessages().  It is rather simple; it just asks for a feature layer and then uses arcpy.GetCount_management() to print a count of the rows in the feature layer.
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Tool"
        self.description = "Get count of items in feature layer"
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # First parameter
        inFeature = arcpy.Parameter(
            displayName="Input Features",
            name="inFeature",
            datatype=["GPFeatureLayer"],
            parameterType="Required",
            direction="Input")
        params = [inFeature]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        inFeature = parameters[0].valueAsText
        arcpy.GetCount_management(inFeature)
        # last tool used: GetCount
        return‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The script will display the following messages (rows 4-7 are from the GetCount tool):
Executing: Tool "MyFeature"
Start Time: Thu Jan 10 20:24:08 2019
Running script Tool...
Executing: GetCount "MyFeature"
Row Count = 2965
Succeeded at Thu Jan 10 20:24:08 2019 (Elapsed Time: 0.00 seconds)
Completed script Tool...
Succeeded at Thu Jan 10 20:24:08 2019 (Elapsed Time: 0.05 seconds)
If line 50 --  arcpy.AddMessage(arcpy.GetMessages()) -- in the python toolbox is commented out, the following messages are displayed (the output of GetCount_management is suppressed):
Start Time: Thu Jan 10 20:26:00 2019
Succeeded at Thu Jan 10 20:26:00 2019 (Elapsed Time: 0.05 seconds)‍‍‍‍‍‍‍‍‍‍
Hope this helps.
