ArcPy: Finding Local Maxima of Groups in an Attribute Table
1520
10-21-2014 02:10 PM
kevinkent
I'm still a beginner with ArcPy and I'm wondering how I can write a script that can iteratate through a table and find the LOCAL maxima of each group
I've spent a lot of time looking into the arcpy.da.UpdateCursor module but I can't figure out how to go group by group and look at values in more than one row at a time.
Can this even be done? I've also looked at converting the table into a NumPy array but I am also lost there.
I've included this example to illustrate what I'm looking for. I am thinking using the update cursor to change the values of Field 03 from 0 to 1 for the records that represent local maxima would be helpful but I'm sure there are other ways to go about this.
Field 01: Group(Integer)
Field 02: Length(Double)
Field 03: For Flagging desired fields(integer)
ID     Field 01  Field 02     Field 03
01     10          07.0               0
02     10          09.0               0
03     10          03.0               0
04     10          11.0               0
05     12          18.0               0
06     12          16.0               0
07     12          02.0               0
08     12          07.0               0
09     12          04.0               0
Results would be:
02     10          09.0               1
04     10          11.0               1
05     12          18.0               1
08     12          07.0               1
Thank you for any help.
DallasShearer
the summary statistics tool may be the easiest for you to implement.
ArcGIS Help 10.1
kevinkent
Thanks for the suggestion but as far as I know summary statistics would only work if there was one maximum for each group. Some groups have multiple local maxima that I need to find also.
